help with iac valve...
Old Aug 30, 2009 | 06:32 PM
crf inc.'s Avatar
Originally Posted by imalancerman
Yes my extra has 50k on it and came off a perfectly running motor. Whats reasonable to you?
hmmm, well i think a used one should go for about half the price of a new one.. and that link i posted it goes for about $130.... i dont wanna sound like im low balling though so i really have no idea...lol
Old Aug 30, 2009 | 06:54 PM
imalancerman's Avatar
75 bucks? It goes on rockauto for 400 new. I laughed when i found that.
Old Aug 30, 2009 | 07:15 PM
crf inc.'s Avatar
75 shipped? or 75 + shipping? im probablydown to do that though
Old Aug 30, 2009 | 08:09 PM
id do it 75 shipped. I see your down in socal, are you on sclc.net?
Old Aug 31, 2009 | 12:49 AM
crf inc.'s Avatar
yes sir i sure am... i go by the name of HOTCARL...
Old Aug 31, 2009 | 01:18 PM
im slow z rally. Anyways, if you want that piece, just pm me and ill send you pics of it if you want. Or send you the paypal address. Its not going anywhere so just let me know whats up. Im on sclc.net far more than im on here.
Old Sep 1, 2009 | 01:29 PM
crf inc.'s Avatar
Y
yeah ill send you a pm on sclc later today.. Probably won't be able to get it for a week or so..
Old Sep 1, 2009 | 01:31 PM
k its all good.
Old Sep 9, 2009 | 05:26 AM
03dancer's Avatar
I had the same rpm fluxuation problem... It wasn't the iac... Start ur diag with pulling the vacuum hose off the egr valve plug it off by putting a bolt into it... Drive it for a couple hours see of it acts up... If it doesn't then it is the vacuum contol valve for the egr valve... Take that off and clean it out with carb or brake cleaner... That should fix ur problem... It fixed mine...
Old Sep 9, 2009 | 09:43 AM
03dancer's Avatar
Everyone tried telling me it was my iac also cause u could ok it out clean the carbon off and it was fine and go back to wheee it was (update) it's prolly not ur iac
Old Sep 10, 2009 | 08:43 AM
crf inc.'s Avatar
Thanks guys but I'm not going off what people tell me they think it is... The computer is telling me its the iac valve.. My cel is on because of it.. I've had a diagnostic check done on it already.. And I don't think the computer lie..lo
Old Sep 10, 2009 | 11:15 AM
03dancer's Avatar
Well just trying to help u out **** for te lancer isn't cheap but u don't have to listen to what I had wrong with mine but just try one thing there is a vacuum line on top of the intake manifoldshould have a green line on it if it's still the factory one pull that off of it stops acting up then the problem ur having is what I explain earlier cause I have the MIL light on also reading iac...... Try it all before u throw parts what I been taught in shops... Update us on why u find put then... Good luck bro
Old Sep 10, 2009 | 11:21 PM
crf inc.'s Avatar
yeah man ill try it out.. and i wasnt tryin to sound like a dick or anything....
Old Sep 11, 2009 | 03:55 AM
03dancer's Avatar
It's chill good luck
Old Sep 14, 2009 | 12:25 PM
miksatx's Avatar
what's the curb idle speed for your car? from a cold start run it till the fan cycles check the rpm after the fan shuts off. if it's lower or higher than suggest curb idle. ajust the biss screw to the curb idle. take it for a drive see if thats better.
