Good Base Map For Me?
Old Aug 30, 2009 | 04:05 PM
03lances's Avatar
Talking Good Base Map For Me?
Ok ecuflash guru's, this is my very first attempt at changing anything in ecuflash. My 03 es will be turbo'd within the next 2 months and so I wanna make sure I am comfortable with tuning when the time comes so here is my stock fuel maps (TOP) and my altered fuel maps(BOTTOM), I will be running 440 injectors and rescaled my injectors to 412. I found This for the stock latency values of the 440's but it only shows 5 values and ecuflash gives me 7 to define so how do I adjust these? I have not rescaled the timing maps yet and dont know if I should or wait until after I datalog some
I want a good base map to start with so any advice on changes pease let me know!!!! As I stated this is my first attempt so feel free to give me any tips thanks
Old Aug 30, 2009 | 06:23 PM
senate6268's Avatar
You might want to take a look at this link:
https://www.evolutionm.net/forums/5889337-post4.html
Old Aug 30, 2009 | 08:10 PM
JRR's Avatar
JRR
^^+1 that help me with my latencies!
Old Aug 31, 2009 | 01:51 AM
03lances's Avatar
Yes thank you senate I just read through the sticky "How to tune your evo" in the evo tuning forums today and he mentions the fuel trims in regards to latencys as well. Ok so how about my load scaling and the afr values I put in as a start, do they look conservative? Should I do any leaning out yet? Or maybe just start with this and log to see what the next step is?
Old Aug 31, 2009 | 04:17 PM
senate6268's Avatar
Start here and datalog. On a side note, there probably isn't a need to have two running threads that are both now focusing on your tune.
Old Aug 31, 2009 | 04:30 PM
03lances's Avatar
True this one really isnt needed wasnt sure if I was going to get much help on my build thread but I was wrong lol
Old Aug 31, 2009 | 04:35 PM
03lances's Avatar
Thread no longer needed thank you!!!!!!!
Old Sep 2, 2009 | 11:44 PM
ThunderOZ's Avatar
So as not to pollute the rest of the forum, does anyone have a base map, I somehow lost mine, and my tune is completely f**ked up right now...
Old Sep 3, 2009 | 10:30 AM
ClixT's Avatar
i have mine but, our ecu id is different. it might brick your ecu.
EDIT: pm sent thunderoz
Old Sep 3, 2009 | 11:57 AM
ThunderOZ's Avatar
Thanks, I would just copy values anyway...
Old Sep 3, 2009 | 01:21 PM
JRR's Avatar
JRR
u looking for the base oz map? i can send u mine if u need it. dont think theres any difference in ecu's from 02 to 03 lancer oz's.
josh
Old Sep 4, 2009 | 12:24 PM
ThunderOZ's Avatar
Ok I got it... Now I just have to get this tune down...
Fast_Freddie
Oct 30, 2023 01:56 AM
domyz
Jul 27, 2022 11:54 AM
babaz7
Oct 12, 2011 08:11 PM
lncrphish
Lancer Engine Management / Tuning Forums
15
Aug 3, 2010 06:48 AM
03lances
Apr 17, 2010 12:28 AM
