Timing Map Explanation?
this one screen shot only shows us 1000 rpm range and like 2 and a half of the values lol, if anyone can tell me how to just view certain ones as I am sure there is a way to do it tell me and I will post some more screen shots with everything
so heres my modified log from normal cruising. (thnx to photoshop)
theres a bit of WOT on in it and thats the only thing im gonna put in here.
oh and sorry for the HUGE pic...
Looks like you are having the same issues with load as I was are you logging ecuload as well? I was logging loadcalc for awhile until senate set me straight, I was getting the high load values too until I rescaled the injector size in evoscan back to the factory 232 since default in evoscan is evo factory at 513
I would recommend to just log RPM, knock, AFR, timing, and load.
This will give you a better resolution in your logs.
Before you prt sc try to adjust your screen resolution to it's maximum.
Ya I only logged a few items but it still gives me all the values in the log just the ones I have unchecked are just the blank rows not sure how to get rid of the blank rows
