how to log your AEM EUGO with evoscan
Old May 31, 2011 | 05:20 PM
  #46
milford's Avatar
well i got everything to work..almost. I can successfuly log AFR in evoscan. However i can only view the date when i view it in excel. I cant get it to show up when i choose " view log in graph" anyone know why this is happening? Thanks in advance!
Old Jun 1, 2011 | 05:03 PM
  #47
milford's Avatar
bump
Old Jun 14, 2011 | 05:24 PM
  #48
enash99's Avatar
Ok so I have been playing with this formula. I have mine all setup but this formula is not accurate at all. In fact it seems to drift thewrong way at times. Now my setup maybe wrong. I was told to have my guage in P04 mode. Is that correct?
Old Jun 17, 2011 | 07:57 AM
  #49
slatermvp's Avatar
What about those not running the evo ecu but have the lancer ecu...what pin do we use??
Old Jun 30, 2011 | 12:16 PM
  #50
steven121's Avatar
Easier Way to Log
I cant believe I didnt see this earlier and for those that dont know.
Buy a DB9 cable with 2.0 Usb port, Then you buy this black connector to to plug it in then the 2 wires coming out go to the end cables of the AEM Eugo
http://www.bustedfingermotorsports.c...emstockpic.png
Im going to buy this piece and I wont have to worry about logging issues anymore or splicing wires to make this work...
Old Jun 30, 2011 | 12:20 PM
  #51
Timmay81's Avatar
why do that when you can do it with 1 wire through the ecu and not have to worry about another usb port
Old Jun 30, 2011 | 12:51 PM
  #52
steven121's Avatar
im not really an electronics person and I will never solder anything in my cars computer... But I just found out a better way that is easier than spending $20.00
get 16 gauge wire cut it, and push it in the 2 pins then get some super glue or JB weld and fill it in the pin area so the 2 wires stay there permantly. I just did this and Ill admit it was dumb for me to say buy the item I mentioned above
Old Jun 30, 2011 | 01:02 PM
  #53
Timmay81's Avatar
when i did mine i didnt even solder i just used a white cap like you do when installing stereos, worked fine for me
Old Jun 30, 2011 | 01:15 PM
  #54
HornstarBU's Avatar
I use inline crimpy thingies....but I still don't like wiring the wideband of AEM's into the ECU. For some reason, I see too much talk about it being inaccurate. One thing that is neat, is the OpenPort 2.0 supports serial in, so you can wire the serial out on the aem wideband to a serial plug, that you can use on your computer, or you can use the standalone logging, and plug the serial into a converter to a headphone jack, plug that into the openport 2, and setup logging there.....self contained, accurate as hell, and pretty dang easy, if you have an OP2.0
My one issue with that, is that the logs don't open nicely in EvoScan.
Old Jun 30, 2011 | 01:20 PM
  #55
Timmay81's Avatar
yea i just liked plugging my tactrix in and pull up evoscan and boom everything all in 1, mine was damn accurate at most was off by .1-.2
Old Jun 30, 2011 | 05:24 PM
  #56
HornstarBU's Avatar
si si, if you run the serial out to the serial in, then you can also log with no cables, which is 1 less then 1. Also, 1 less computer.
Old Oct 8, 2011 | 07:25 PM
  #57
EvoIIIAj's Avatar
Question: I have a JDM Evo III. My ECU is different than the USDM. I have found a PIN out for myself but I don't have the rear o2 so where would I wire my AEM Wideband into to mke EvoScan log AFRs??
Old Oct 9, 2011 | 10:24 AM
  #58
EvoIIIAj's Avatar
Bump
Old Nov 11, 2011 | 12:01 AM
  #59
chaosfiend21's Avatar
Hey guys, I can log but formula seems way off reading 9s when gauge reads 14s should i just add the difference to last number on formula?
Old Nov 11, 2011 | 05:52 AM
  #60
HornstarBU's Avatar
Bump
Pin 75 is "O2 Sensor Rear" do you have the same ECU that I do? and that the Evo 8 does?
http://www.roadraceengineering.com/e...-ecuwiring.htm
That's really far off...which formula do you have?
