Is this Tephra safe for my base Lancer?
Old Oct 4, 2010 | 01:03 PM
HornstarBU's Avatar
I've taken the stock map, and done all the changes listed in Senate's post for getting the EVO Rom working on a base lancer.
I have also changed:
Off all Tephra except cel on knock
hi/lo octane/timing maps ...probably no where near correct for boost
openloop load/throttle tables
idle settings, but not a few...which concerns me.
rev limit, immobilizer, knock multi's/gain's
Periphery1 (FBA) to turn off leanspool
Can anyone with tuning exp look...as long as you are bored and not busy doing anything else, and tell me if I either did anything stupid or am missing copying any values over (or if i copied something over that i shouldn't have, like the idle stuff)
I also had some trouble with MAF Scaling, and had to change the item that was being used for scaling...but i think i got it all in there right. Still, that's why i ask if anyone can take a look. I'm not flashing it yet, still don't have the turbo on. Installing next weekend or the following, so plenty of time to keep learning.
http://www.filefactory.com/file/b3da...ZwhenTurbo.zip
My setup will be:
stock injectors for now (440's eventually, but not till the ceramic "cooks" onto the exhaust)
stock MAF for an 03 lancer
stock everything pretty much
turbo will be evo8 16g custom kit
Thanks for any help, or if you want to email me your tephra rom used on a stock lancer...that helps as well for comparison reasons.
