Is my Lancer a gts?
Old Jan 15, 2012 | 09:20 PM
wumbster's Avatar
Is my Lancer a gts?
Recently got a 2010 Lancer about 3 months ago. The car is used with 12,000 miles and the salesman claimed it to be the GTS model. It had a stock spoiler, an exhaust tip, and paddle shifters. The only thing is, under the hood the engine sticker says it is a 2.0 liter engine. GTS engines are 2.4. Is the sticker wrong? or is my car not a GTS?
Thanks in advance
Old Jan 15, 2012 | 10:16 PM
SYSTEMA's Avatar
Thanks in advance
thats weird. you do have a gts because of the paddles, but if you think you have a 2.0 engine than you may have bought a 2008 gts
check the engine code that is engraved where the oil filter is mounted.
open you hood and look down in the space in between the radiator and the plastic intake manifold.
you should see a piece of metal that has the oil filter below it.
on that piece of metal there should be one of three codes
4b10 is the 1.8L
4b11 is the 2.0L
4b12 is the 2.4L
post a pic of your engine bay and i might be able to tell based on the engine cover.
Old Jan 16, 2012 | 11:35 AM
LiX's Avatar
LiX
Guys, I'm surprised how you in the States don't know what car you bought....
I have seen similar threads..
Old Jan 18, 2012 | 06:33 PM
wumbster's Avatar
I found the solution thanks to another section in the forum. Appreciate it tho!
Old Mar 14, 2012 | 07:33 PM
nsxiphos's Avatar
what was the problem? sticker gts?
Old Apr 13, 2012 | 08:01 PM
qJai's Avatar
sounds like a 2008 gts. 2008 gts is 2.0. im not 100% sure but 2009-2011 were 2.4 i think.
Old Apr 14, 2012 | 08:08 AM
timereaper's Avatar
From 2009 model and up is 2.4 litre. Only the first year 2008 lancer gts came with 2.0
Old Jun 19, 2012 | 10:18 AM
gtsAndi's Avatar
I have a 2009 GTS and it is a 2.4 litre. There's no way that a 2010 is a 2.0 litre. A picture of the engine, as suggested before would definitely solve this issue. I'd also be interested in hearing what the other section of the forum said was the issue...
Old Feb 25, 2013 | 03:44 PM
Rvargas GTS's Avatar
I work for mitsubishi now. And i sold a car like that one its not a GTS. This is a ES With a Sport pack...
Old Mar 1, 2013 | 02:25 PM
SYSTEMA's Avatar
if you're selling in the US, the ES never came with paddle shifters. Op mentioned that his lancer had paddle shift.
Old Mar 7, 2013 | 03:49 PM
zlatsky's Avatar
if only you were right and the gts didn't come with the insanely underpowered 4b11.
Old Mar 8, 2013 | 07:21 PM
SYSTEMA's Avatar
wah? not sure if sarcasm or ignorance. (or if this was even directed to me)
in 2008 the gts did come with the 2.0 4B11. 2009+ gts's had the 2.4 4B12. Both the 4B11 gts and the 4b12 gts came with paddle shifters as standard equipment.
In 2009 there was the ES and the ES SPORT. both had the 4B11 but the ES sport had the exterior styling of a GTS with the front airdams, side skirts, rear spoiler, and exhaust finisher standard. What the ES SPORT didn't have that the GTS did was 18in alloy wheels, front strut bar, and paddle shifters. (it also had larger front and rear swaybars and larger front and rear brake disks than the ES SPORT)
However, you can install paddles on 2008-2010 de's and es's equipped with the CVT. All you need to do is find a set of paddles for a gts and install them yourself. You can also install the floor shifter from a GTS, both paddles and floor shifter are plug and play and will allow you to go into sport mode.
But in the US, the 2008+ ES never came with paddle shifters.
Old May 13, 2013 | 10:45 PM
wumbster's Avatar
4b10 is the 1.8L
4b11 is the 2.0L
4b12 is the 2.4L
Late response but the engine code is 4B12 so it does suggests that I have a 2.4 GTS. It just ticks me off because under the hood, the sticker which the manufacturer puts on says 2.0 L but the rest of the car's interior and exterior suggested otherwise. Thanks all who helped, feel free to keep on posting. Helps a lot!
Old Oct 6, 2013 | 11:28 AM
kodabear's Avatar
ive got a 2.4L in my gt. its 2012 though. i feel like its a gts though. and sooo hard to find parts for it because its 2.4L any thoughts?
Old Oct 16, 2013 | 06:03 AM
icedtc's Avatar
Have you tried ebay? I know some things are really lame on there but every now and again you find some gems even for a 2.4.
