Tuning the turbo lancer
Old Jun 15, 2012 | 01:46 PM
marcouxa1's Avatar
Hey guys i was wondering if anyone had maps for a AT 04-06 lancer running around 10-12 psi so i can have an idea of where to start with the tuning part of my project! if anyone has helpful tips they're really appreciated. Thanks!
Old Jun 15, 2012 | 02:04 PM
CrAnSwIcK's Avatar
the tune will depend on the turbo and what injectors you are using...
Old Jun 15, 2012 | 06:49 PM
marcouxa1's Avatar
Currently im using the td05hr 9.8 evo 8 turbo and injectors for now are stock but i am buying the wrx 440cc injectors this week so a before and after injectors would be awsome! and btw this is the 2.0l engine 4g94
Old Jun 16, 2012 | 12:03 AM
slatermvp's Avatar
I'm only running 5psi otherwise I would hook you up with what I got to get you started.
Old Jun 16, 2012 | 12:57 AM
ryancb's Avatar
honestly u shouldn't be over 5psi to start, stock block and 10-12psi u can go pop easy not knowing what your doing. IMO i would pay for a tune unless you have a lot of time and empty flat long roads
Old Jun 16, 2012 | 06:38 AM
marcouxa1's Avatar
I do have alot of time i have 2 cars this one is on standbuy and still needs an exhaust and the arp headstuds...but im going straight to 10-12 psi for sure i have the stock wga installed!
Old Jun 16, 2012 | 06:59 AM
ryancb's Avatar
uh stock wg we didn't have a stock wg, and if you mean an evo 8/9 wg thats more then 12psi if i recall. Enjoy going boom cuse your ego doesn't want to start safe and build it up. Theres a reason a few of us are at 14-15ish psi on stock blocks, cuse it was tuned from 5 up safely. Lot easier to add a few load cells vs 200 right away. Not to mention all the fun your going to have with the MAF since the 605 cut do 12 psi iirc as well. or at least not as well.
Old Jun 17, 2012 | 12:08 PM
marcouxa1's Avatar
Yea im having trouble with the maf i think cuz when it starts boosting it cuts power right when the maf sees 500 and up
Old Jun 18, 2012 | 05:21 AM
Green_Bandit's Avatar
It cuts power? What are you trying to describe?
Old Jun 18, 2012 | 06:20 AM
ryancb's Avatar
Just give up now green he already knows everything...
Old Jun 18, 2012 | 07:34 AM
Yeah, he definitely is all over the place. It's kinda hard to get a dial on exactly what's going on with him.
Old Jun 18, 2012 | 10:05 AM
marcouxa1's Avatar
yea the power cuts cuz the maf reads 1500 kpa at around 5-6 psi of boost i guess i have to adjust the maf scaling right?
Old Jun 18, 2012 | 10:58 AM
jakermeister's Avatar
I'm guessing he's using the stock MAF
Old Jun 18, 2012 | 02:57 PM
marcouxa1's Avatar
Of course i am!
Old Jun 18, 2012 | 08:23 PM
Swap to a evo MAF then
