Request for a non-turbo, "stock-ish" lancer 02-06
Would it be possible for someone out there to log the timing, tps, load, rpm, speed and maybe wideband if you have it for a bone stock or close to it (non-turbo) running the stock ECU flash with an openport cable?
I don't know if anyone out there has one like this, but I'd like to see what sort of load and airflow you hit taking off slowly from a stop, as if you were just normal driving to work. Also, could you log cruising on the highway at 80? I am hoping someone can do this for me just as a favor, because I'm a little fuzzy on how I want to tune my car outside of boost. In boost, I know where I want it, but it's the cruising and idle, and inbetween that is giving me trouble.
Thank you for any help you can give.
Would be reasonably epic. My issue is I can't seem to make the car all that happy outside of boost. Cruising, idle, warm up...so I'm trying to pinpoint what the heck I'm missing.
I have a few logs for my NA and since my build is at a standstill at the moment, I can send them to you. The wbo2 is not available in them because Im questioning my wbo2 readings. Message me if youre still looking for them and I dont mind logging some things as its still a NA lancer with a lot of bolt ons.
JasonByeon
Lancer Engine Management / Tuning Forums
Aug 28, 2017 08:12 PM
jimbo74
May 12, 2015 11:40 AM
LordCthulu
Nov 3, 2009 02:31 PM
rambozotheclown
Jun 23, 2004 06:58 AM
