Need definition for 09 lancer de M/t
Old Jan 27, 2021, 06:30 PM
09lancerde340's Avatar
Hey forum, as the title states i am in need of the xml def for an 09 lancer de USDM 5spd M/T. I have attached my base rom freshly pulled from the ECU any help would be much appreciated. I don't mind donating for the assistance. Edit here is my ecu ID: 53220004
Old Aug 1, 2021, 05:00 AM
NKTA's Avatar
There's no ROM added to your post, you will have to confirm if your rom id is correct. Address 5002A.
On Ecuflash, you can always insert the data manually.
Use at your own risk, try to confirm with a more experienced user if everything is ok.
File Type: xml
Old Sep 26, 2021, 06:26 PM
Thank you, this helps alot. Will be testing shortly.
Rey D
Apr 21, 2021 10:40 AM
nikush
Aug 15, 2020 07:42 AM
Abryant1985
Lancer Engine Management / Tuning Forums
May 29, 2020 09:21 PM
greder
Jan 30, 2015 09:41 PM
dadsgts
May 1, 2010 09:12 AM
Quick Reply: Need definition for 09 lancer de M/t
