I need to know something, pretty simple I guess
Old Dec 6, 2001 | 12:04 PM
lionken07's Avatar
how soon will you know before your engine is starting to overheat? I mean of course before checkin' under the hood.
Old Dec 6, 2001 | 01:28 PM
EVOwhat's Avatar
the temp gauge inside your car goes too high.
ryan
Old Dec 6, 2001 | 02:04 PM
lionken07's Avatar
yeah that's what I thought
let's say your in the middle of the stateside highway and the temp suddenly point to hot do you just put some water in (assumin' you got a water bottle or two), or you can pee in the coolant tank?
Old Dec 6, 2001 | 03:16 PM
EVOwhat's Avatar
i would say pull over and pop the hood. just be careful. look at your coolant reservoir and see if there is enough coolant. if there isn't, and you're stuck in the middle of nowhere, i would put water or **** in it if need be. just be careful of your pecker (or ***) depending on sex -- might get toasted. if there is enough coolant, probably your thermostat is shot.
happened to me in chicago. i was driving towards mccormick place when i saw the needle just skyrocket. pulled over, popped the hood and looked at the reservoir -- looked ok. then i noticed my upper radiator hose. damn thing was honking!! looked like the size of a football. thermostat needed to be changed.
ryan
Lexi Butler
Sep 23, 2016 05:01 PM
104792700
Jul 19, 2016 04:18 PM
Bmurray
May 30, 2015 04:31 PM
rallylanceroz03
Nov 21, 2006 04:02 PM
jmartinez1170
Oct 5, 2005 11:15 PM
