What else to change when timing belt is....
Old Oct 11, 2004 | 09:04 AM
Kelspar's Avatar
I am gaining knowledge as to how to completely change my timing belt and all other things that you "should" change with it. My car has 76k on it and im sure it wouldnt hurt to do it. My question is what else should i change along with my timing belt? I've heard that you should change your water pump with it. Anything else? Also, has anyone compiled a DIY on this? Lol it maybe a bit hard for a DIY but im up to it. Thanks
Old Oct 11, 2004 | 10:27 PM
Nad1370's Avatar
Crank and Cam seals are a must even though if its not leaking.
Thermostat, if your changing the waterpump. Drivebelts. Also check all your idler bearings for play.
