Hneycomb filter
Old Nov 22, 2002 | 09:10 AM
ROB281's Avatar
Honeycomb filter
My friend was trying to install the intake on his lancer the other day, and ended up having the same problem we've all had well he ended up totally destroying his honeycomb. My question is has anyone in the forums purchased just the honeycomb for the mas if so how much did it cost. He doesn't have much money to spend so we're trying to find out. Thanks for any info
Old Nov 22, 2002 | 09:27 AM
HobieKopek's Avatar
*points at where the thread is located* Your friend drives an Evo, eh?
He will have to buy a whole new MAS most likely. They're not cheap. Unless you have the fortune of finding a rear ended Lancer in the junkyard it'll cost you a pretty penny. Until then expect rough idles, possible stalling and a CEL.
Old Nov 24, 2002 | 05:41 PM
OZLancerlunatic's Avatar
Thats a negative HobieKopek.........you know mine was stalling....that was cause the ECU didnt recongize it......but I have no screen....and still do not have a screen.....reset your ECU, let the car idle normally, and just leave it out until you can find a replacement.
Old Nov 24, 2002 | 06:23 PM
ROCK's Avatar
Honeycombs straigthen out the airflow so the mas more accurately measures it. It is important.If you lie to ECU with an AFC or something else it may be OK.
ROAD/RACE
http://www.roadracemotorsports.com/
Old Nov 24, 2002 | 06:58 PM
ryancb's Avatar
hum if car hasnt stalled or cel light after about 30 min of idle is it mean its ok ?
Old Nov 24, 2002 | 07:30 PM
been driving without my filter for a week now......no problems....we'll see what happens
Old Nov 24, 2002 | 08:29 PM
HobieKopek's Avatar
Like Rob said, the honeycomb is there for a reason. If your car isn't having issues yet, it may begin to in the near future. Without a new MAS, filter or air/fuel management, you're likely to run into problems.
Old Nov 24, 2002 | 08:47 PM
u can order just the screen....go to ur dealer.....
Old Nov 24, 2002 | 09:04 PM
ryancb's Avatar
you can? how much is it at yours?
Old Nov 24, 2002 | 09:10 PM
no clue...i didnt order it...my cousin whos a mechanic is getting it for me...he told them he was working on my car and broke it.
Old Nov 24, 2002 | 09:12 PM
ryancb's Avatar
LOL hey can u ask and get back 2 me on it?
Old Nov 24, 2002 | 09:26 PM
why you need one too?
Old Nov 25, 2002 | 04:28 PM
hardcoretuner's Avatar
question: i put my intake on and had no problem, i didn't destroy anything not tryin to b a smart @$$ but what went wrong? is it because i have an rmr one that bolts up to the MAS without moving it?
and a related note
is there such thing as a high performance MAS if so how much and where should i look to find it?
Old Nov 25, 2002 | 04:37 PM
pjal84's Avatar
It has nothign to do with brand. Either you didn't reset it or there is another problem (loose seal, vacuum hose etc.). As for the MAS, you can swap but it's not easy and you'll want some good mods before hand. It's been mentioned before, use the happy blank box at the top to find out more.
Old Nov 25, 2002 | 05:19 PM
GSRX7's Avatar
this gives me an idea, Hey, Rock do you guys have plans to produce maybe a "hot wire" style MAP sensor to replace the MAS? it might be te answer to everyones problem depending on cost, and if not, it would still help out with tuning, especially with turboin when the boost starts to go up when your low compression pistons come out. do you think you could get the ecu to work with it or would it take stand alone engine managment? well anyway what are everyone's thoughts on this?
