Hneycomb filter
Old Nov 25, 2002 | 05:50 PM
LBLancerDude's Avatar
interesting concept
Old Nov 27, 2002 | 10:29 PM
eslai's Avatar
Originally posted by GSRX7
this gives me an idea, Hey, Rock do you guys have plans to produce maybe a "hot wire" style MAP sensor to replace the MAS? it might be te answer to everyones problem depending on cost, and if not, it would still help out with tuning, especially with turboin when the boost starts to go up when your low compression pistons come out. do you think you could get the ecu to work with it or would it take stand alone engine managment? well anyway what are everyone's thoughts on this?
Too bad that's impossible to do. You can't just swap in a MAP sensor. If it were that easy, the HKS VPC would never have been invented.
You won't switch to MAP without switching to an EMS or other such stand-alone management.
Old Nov 29, 2002 | 07:06 AM
hardcoretuner's Avatar
Originally posted by pjal84
It has nothign to do with brand. Either you didn't reset it or there is another problem (loose seal, vacuum hose etc.). As for the MAS, you can swap but it's not easy and you'll want some good mods before hand. It's been mentioned before, use the happy blank box at the top to find out more.
when you say i didn't reset it what do u mean, i unhooked the battery the entire time so my entire electrical system would reset should i have done/ go do something else ?
Old Nov 30, 2002 | 02:04 PM
GSRX7's Avatar
no, unhooking the battery should take care of it. but something else i have heard is that after you reset it you ned to start the car without hitting the gas and let it idle for a while before touching the gas.
WiLancer
Jul 28, 2014 07:45 PM
btmboards
37
May 21, 2012 05:30 PM
Dragking2189
Apr 1, 2009 08:31 PM
Boostin4g63
Jun 21, 2007 09:39 PM
alex_alex
16
Sep 8, 2003 03:28 PM
