rrm pb ecu question
Old Nov 3, 2004 | 09:05 PM
AZMATT's Avatar
rrm pb ecu question
Hi, I did a search on the piggyback and i saw that someone said it only deals with the a/f ratio. Can someone confirm this or let me know exactly what it does? All of the posts i've seen on it got me a little confused. My buddy told me that if thats all it does, its probably better just to buy a afc and he could set it for me for free. If this is true i'd rather save a little money and do whichever is better. Thanks for the help, Matt
Old Nov 3, 2004 | 11:43 PM
pgmike's Avatar
yes it only controls af ratios, not timing.
Old Nov 3, 2004 | 11:55 PM
lookslikeanevo's Avatar
safc will not work unless you get anoher MAF...and will prolly run you more than the piggy after everything
Old Nov 4, 2004 | 12:39 AM
rhyzin's Avatar
eh, that's not entirely true... after i found out what the piggyback actually was, things started to make a bit more sense. the piggyback does what a regular safc does, which means it has the same limitations. if a piggyback works, then a safc should yield similar results. if it's proven that you can't add correction with a safc, then logically, neither can the piggyback. with the SAME MAF, mind you. this would also logically follow that the piggyback is only taking away fuel. if you have an safc, you just need a wideband to adjust it and that's it. i'm really hoping that if i'm wrong that someone WILL say something. but i'm pretty confident at the moment. but that doesn't usually mean anything.
the only real difference between the safc and piggyback is that the piggyback has 200 points of correction throughout the rpm band as opposed to the 8 in a safc-II ver 1. i think the version 2 has 12 or 16 adjustable points? can't remember.
Old Nov 4, 2004 | 12:42 AM
kris, how easy would it be to do what your taking about>?
Old Nov 4, 2004 | 12:45 AM
but after the safc and a wideband...wouldnt you be over the price of the piggy
Old Nov 4, 2004 | 12:52 AM
rhyzin's Avatar
yeah, if you have to buy a wideband, that's at least $330. brings the total to maybe $530. the thing tho was that he said his friend could set it for him. this brings it back down to maybe $200. if his friend doesn't have a wideband, he won't be as precise as the RRM piggy and either screw up and have a ***t fuel curve(like mine) or not have as much gain as the RRM piggy.
if you've got a wideband(or access to) it's not that hard since you're just subtracting at certain places. it's not like you're starting from scratch. keep subtracting at a certain rpm until you've got the right AF reading. i wouldn't suggest this to a n00b, but it is possible.
Old Nov 4, 2004 | 12:53 AM
rhyzin's Avatar
also, bringing down the AF curve means you'll probably need higher octane gas. i hate gas prices.
Old Nov 4, 2004 | 12:56 AM
yeah especially when it $3/gal
Old Nov 4, 2004 | 08:22 AM
WADADLIG_OZ's Avatar
Well as they say you gotta pay to play when it comes to performance.
WADAD
Old Nov 4, 2004 | 03:58 PM
AZMATT's Avatar
Thanks for the responses, it definately helped
3bar_dc2
Feb 29, 2016 01:22 PM
Buksh
Jun 17, 2007 10:41 AM
MyEvoRocksUrv8
Apr 11, 2007 05:43 PM
Carbonics
Mar 19, 2005 03:58 PM
EVILEVO13
West Region
Nov 3, 2003 08:59 PM
