Nos No Good
Old Dec 30, 2002 | 07:59 AM
mandasOZ's Avatar
That was a 50 shot. I will not run NoS in the lancer even after The pistons are upgraded. But it will Be a 9to1 compression 100 shot should be fine.
Old Dec 30, 2002 | 08:03 AM
HobieKopek's Avatar
So that's what you've been doing, Amanda? Massacring pistons with Nitrous? I'm assuming you were running dry shots?
Have you considered just using a wet system to keep your engine from running horribly lean when the N2O is introduced? It's a far safer way of doing it.
Old Jan 3, 2003 | 01:53 AM
pearlwhiteoz's Avatar
Dang........no engine...getting a new engine rebulit and turbo now?
Old May 7, 2003 | 06:09 PM
adhem_t's Avatar
i was thinking of putting nos in kine what is the safest amount to run..35 shot?
Old May 7, 2003 | 06:32 PM
pisetup's Avatar
I was also wondering about NOS, NOPI.com sells two types. Which one is safe for the Lancer??
$777.24
"FAST AND FURIOUS EDITION - Import EFI Single Nozzle Nitrous System (35-50-75 HP) - 10lb Bottle BLACK with GREEN Label/16ft Line (D-4) GREEN - Complete kit including Pure-Flo Bottle valve, 60 amp H.D. relay, WOT switch, all HP settings shark nozzle, stainless steel bottle brackets, 16ft stainless braided -4 sup "
$561.94
"Import EFI Single Nozzle Nitrous System (35-50-75 HP) - 10lb Bottle/16ft Line (D-4) - Complete kit including Pure-Flo Bottle valve, 60 amp H.D. relay, WOT switch, all HP settings shark nozzle, stainless steel bottle brackets, 16ft stainless braided -4 supply line, nitrous filter and installation hardware - Injected Models Only "
Old May 7, 2003 | 10:43 PM
03RallyLancer's Avatar
to me those kits look the same. so more then likely you are paying more for the F&F name and color scheme.
