Buschur downpipe compatible with RRM header?
Old Dec 11, 2002 | 07:44 AM
mcbrown35's Avatar
Rock or anybody else know if the Buschar downpipe is compatible with the RRM header?
Is Roadrace planning on a downpipe?
Old Dec 11, 2002 | 07:53 AM
HobieKopek's Avatar
My thinking is yes, but the best thing to do would be to get one and then the other. If whichever you get matches up to stock positioning then both should fit. Sounds logical enough, right?
Old Dec 11, 2002 | 08:13 AM
swhskenr's Avatar
RRM is plannin on a downpipe, but, I do not know about the compatibility between RRM and buschur. My assumption would be YES that it is compatible. However, you probably would not get the gains that are desired by having matching parts.
BUT.. thats why its an ***-u-m[e]-ption... heheheh
Old Dec 11, 2002 | 08:21 AM
mcbrown35's Avatar
Thanks fellas...If Road Race is planning on it, that's all I need to know...
Old Dec 11, 2002 | 08:23 AM
ghonky2003's Avatar
I don't think the rrm headers are compatible with the br downpipe because the br downpipe has an increased pipe diameter of 2.5
Old Dec 11, 2002 | 08:34 AM
HobieKopek's Avatar
But it also mates to the stock manifold so figure that.
RRM mates to stock downpipe so...logic would dictate they'd bolt right up. Make sense to anyone else?
Old Dec 11, 2002 | 08:37 AM
ghonky2003's Avatar
sounds good to me. I wasn't positive. I'd still wait for rrm to make a downpipe anyway, or at least br to make matching headers.
Old Dec 11, 2002 | 08:38 AM
mcbrown35's Avatar
What would be the benefit of a 2.5" system when it has a bunch of 2.25" flanges to go though?
A water hose with a big fat spot in the middle will not squirt more water ....(over simplification I know but...)
Old Dec 11, 2002 | 09:10 AM
HobieKopek's Avatar
You've still got a cat after the downpipe anyway. There's the real bottleneck.
Unless you plan on running an open exhaust it should still be pretty beneficial.
Old Dec 11, 2002 | 09:26 AM
ghonky2003's Avatar
I think br puts out the downpipe, highflow cat, testpipe, and catback exhaust all at 2.5" so its not so bad if you go with br all the way. Someone correct me if I'm wrong, but 2.5 isn't too much if your going turbo, but imo 2.25 is just finefor any application.
Old Dec 11, 2002 | 09:30 AM
HobieKopek's Avatar
Their and IT's dyno results showed gains in HP and TQ across the board (albeit small ones). Assuming they fit with RMR or RRM headers (which I personally think they will without any problems) it should jump a couple horses at the wheels as well (if not slightly more).
Old Dec 11, 2002 | 02:34 PM
Ranma0's Avatar
the RRW Website has been down for quite some time i belive, and was wondering if anyone has the to them so i can order a header..
Old Dec 11, 2002 | 03:11 PM
HobieKopek's Avatar
RRM or RPW?
Both work fine for me.
Old Dec 13, 2002 | 01:24 AM
pjal84's Avatar
The parts will bolt on fine since all they are doing is replacement of the stock parts themselves. As for Buschur putting out a header, you better convince a hell of a lot of people to buy their other parts since last I heard, they will be dropping Lancer products due to lack of interest.
