lightend fly-wheel
Old Dec 16, 2002 | 05:43 PM
2003lancer's Avatar
lightend fly-wheel
does anyone know if there is a lightend fly-wheel for the lancer yet
Old Dec 16, 2002 | 05:52 PM
JeffCS's Avatar
im pretty sure there isnt one, yet. some people have been dropping hints that one for the 1.9 (i think) L mirage would work on a lancer, but no one has been brave enough to give it a try..
Old Dec 16, 2002 | 05:54 PM
zlancer's Avatar
1.8 L.....but i believe RPW makes a flywheel possibily??
Old Dec 16, 2002 | 06:01 PM
pjal84's Avatar
http://www.boostaholic.net/phpBB2/vi...939&highlight=
The weight of the flywheel is the same as teh origonal. Correct because the origonal flywheel if you look at it has a tin plate in the centre and then metal on the outside. This makes it very hard to make a custom flywheel lighter than the origonal. The problem with the origonal is that it cannot withstand high torque loads on a permanent basis IE turbo and will not handle exotic clutches on there material.
Taken straight from RPW's digital mouth about flywheels.
Old Dec 19, 2002 | 05:50 PM
Joseanevo's Avatar
pjal is right there are no lightweight flywhells available yet , the RPW is just the same except for it being stronger and can handle lots of power and also exotic clutch kits
