Sheet Metal Intake Manifold
Old Jan 8, 2003 | 08:29 PM
hardcoretuner's Avatar
Intake Manifold
would it be any good to even get a sheet metal intake manifold or how about a bigger/better one, or on our lancer is that pretty much just the tb? i have heard of some of my dsm friends sayin they got pretty good gains from it wondering if it would benifit us that much
Old Jan 8, 2003 | 09:51 PM
rhyzin's Avatar
sheet metal intake manifold? sheet metal tb? never heard of that. but there is a sheet metal heat shield for a cone filter. friend has it on a gsx. also seen the ones on vfaq.com. seem like they work well with turbos.
Old Jan 13, 2003 | 01:40 PM
pjal84's Avatar
Making a bigger TB and manifold will help yes, only if you're cramming in a significant amount of air i.e. forced induction. Parts like that aren't the cheapest to get fabricated so make sure you know what you're doing. It may help the DSM's but parts like that are even only for the big boosters of that group.
Old Jan 13, 2003 | 01:43 PM
StreetLancer's Avatar
That, and the real point of intake restriction on the Lancer isn't the TB, but the MAS. That'd be something I'd try and "solve," before the TB.
Old Jan 13, 2003 | 04:45 PM
rhyzin's Avatar
freeing up the MAS doesn't "feel" like it helps any. i could be wrong but i won't know til i get the thing dyno'd. that's pretty much my project for now.
oh yeah, i think dude in a mirage explained why the restrictor is a certain size at different amounts of hp. moving up to a 3rd gen eclipse RS MAS isn't helpful until you're pushing 140hp so using the stock lancer MAS won't need to be changed until then.
Old Jan 13, 2003 | 07:15 PM
right o
Old Jan 13, 2003 | 09:54 PM
Be that as it may, I believe that's the main source of restriction. Whether you "feel" it or not is a different matter. I mean, thing is, you kinda gotta look at from this angle. You work your way in.
Old Jan 13, 2003 | 10:01 PM
ishi's Avatar
Re: Intake Manifold
Wouldn't help that much because the intake ports of the head would still be same size.... much better to port and polish the head first.
Old Jan 13, 2003 | 10:12 PM
ratboy128's Avatar
so you put a third gen eclipse mas in your lancer? did it attach right to the ecu and does the ecu know how to use it? also you said the it would be better after 140 hp, but when would it become too restrictive? i mean when would you need an even bigger mas? if anybody knows the answers to these questions thanks
Old Jan 13, 2003 | 10:42 PM
rhyzin's Avatar
run a search... its all here... well cept for the part about goin over 140. not too many people have gone that far and posted about hacking the MAS. not too many people hacked their MAS period.
Old Jan 13, 2003 | 10:52 PM
ghonky2003's Avatar
I wouldn't think port/polish would be that effective until your running a little higher hp. I don't know if anyone has gained anything on us-lancers from p/p.
96scstang
11
Dec 31, 2015 09:37 AM
okevolutionVIII
Jan 27, 2012 01:55 PM
Tevenor
16
Apr 22, 2008 04:56 PM
Hot Wheelz
Nov 18, 2007 07:50 PM
djevoawhp
18
Oct 28, 2006 03:54 PM
