Engine Swap Lancer OZ V-6
Old Feb 21, 2005 | 10:31 PM
TexasLancer's Avatar
I have recently acquired an eclipse 3.0 V-6 that was a total loss and am contemplating the idea of transplanting the engine/trans from the eclipse into my 2002 Lancer OZ. I was wondering if anyone else had tried this. My prelimenary measurements reveal that it should fit but will no less be tight. Any input would be appreciated.
Old Feb 21, 2005 | 10:36 PM
irulea2's Avatar
I have no input, but wish you luck, it would be really nice if you do get it in there
Old Feb 21, 2005 | 10:47 PM
hybridevo's Avatar
that is hard considering that you have to do a lot of work not just the engine mounts but also getting the engine run and doing also the harnesses for your car but goodluck man
Old Feb 22, 2005 | 05:02 AM
OZLancerlunatic's Avatar
if its the 6a12 it will fit and its been done. check out www.rpw.com.au they have details.
Old Feb 22, 2005 | 04:45 PM
Automatic 51's Avatar
if you pull this off i'm pretty sure you'll be the first. I've always wondered about the feasability of this swap. keep us posted w/pics if you go for it!
Old Feb 22, 2005 | 04:50 PM
xtreme571's Avatar
gud luck...hope it works out well for u
Old Feb 22, 2005 | 05:03 PM
03lancOZ's Avatar
keep us posted... could be a wicked swap
Old Feb 22, 2005 | 06:32 PM
rhyzin's Avatar
eclipse 3.0 has the sohc 6g72. 6a12/6a13 are in the overseas galants. none in the states that i'm aware of.
other people have measured and had thought it's a way too tight fit. don't forget to measure for engine rocking. good luck and hope we another stateside swap that'll fit.
Old Feb 23, 2005 | 04:53 PM
Mitsiman's Avatar
Unfortunalty that engine won't really fit into the lancer chassis too large
The 6A13 series engine sare a lot smaller hence why they fit in
Old Feb 23, 2005 | 04:56 PM
bahamut's Avatar
Any 6g7x motors won't fit. Too small of a motor bay.
Old Feb 23, 2005 | 06:12 PM
Icecube79's Avatar
Anything can fit if you force it
Old Feb 23, 2005 | 06:14 PM
Shingen's Avatar
Or have no hood... Hot Wheel style. Open engine bays mean more power.
Fox
Old Feb 23, 2005 | 06:15 PM
MiVecJohn's Avatar
if you can make a rotary engine fit a honda and make it fwd in the proces...
you can fit it... i believe it can be done
Old Feb 23, 2005 | 06:29 PM
ambystom01's Avatar
With enough money you can do anything, its a matter of whether its all worth it. You gotta worry about both the engine bay size and the hook ups, harness, tranny etc.. Good luck though, if you pull this off it'll definitely be original.
Old Feb 23, 2005 | 07:10 PM
wow put that in a different context.....
