Aftermarket Oil Pump
Old Mar 15, 2005 | 11:59 PM
Evodreamer28's Avatar
I currently own a 2003 Lancer es, I was just wondering if anyone makes an upgraded oil pump or if there is any possible swaps that can be done?
Old Mar 16, 2005 | 12:00 AM
twardnw's Avatar
wow, haven't heard of one, what are you running that the stocker won't supply enough pressure?
Old Mar 16, 2005 | 12:01 AM
Soon to running a turbo setup, and also looking to rebuild the bottom end of my engine.
Old Mar 16, 2005 | 12:03 AM
twardnw's Avatar
well, if it's any help, no one has needed any more pressure for their turbo setup, the stock pump has done just fine, might just spend the money elswhere.
rebuilding bottom end -- you going to be doing the pauter rods?
Old Mar 16, 2005 | 12:04 AM
Not to sure, thinking about it, as far as the pistons go I will not be getting the ones from road race, the dish is not deep enough on them, as well I would like to run a lower compression ratio
Old Mar 16, 2005 | 08:39 AM
KillahB's Avatar
Check out Wiseco... they have Lancer pistons that seem to be great. I know a bunch of people running them and they all have good things to say about them
Old Mar 16, 2005 | 11:07 AM
twardnw's Avatar
Wiseco makes the pistons with a slightly higher compression ratio though. it would be cool for all the turbo guys if we could find someone who made a lower compression one
Old Mar 16, 2005 | 01:47 PM
rhyzin's Avatar
why? 10:1 isn't bad for boost 5-9psi. look at the celica guys. besides, i doubt most of us will be boosting at dsm levels. 10:1 is good for use. better gas mileage, better torque, and more hp per psi of boost. it's just we're limited to "lower" boost due to stock or piggyback engine management. seeing that most turbo guys aren't looking to boost much in the first place, i don't see why you're all waiting for lower comp pistons.
Old Mar 16, 2005 | 08:52 PM
KillahB's Avatar
I disagree. Wiseco has Lancer pistons in both 9:1 and 8.5:1 compression. I dont know if they still make the 8.5:1 (to me, that is too low of a compression and you start sacrificing torque for power) but I know for a fact that they have the Lancer pistons in 9:1 compression.
10:1 isnt bad for that level of boost, but if you are going forged, why limit yourself? 10, 15 shoot 20 psi is obtainable forged (assuming you have both rods and pistons).... And lol, turbo guys already sacrificed gas mileage to attain those numbers. I still feel that you can reach decent levels of boost on piggybacks (under 300 whp) but again, all my premises are based on the 4G93. BUt you are right tho.... all depends on the guy and like yo usaid, most turbo guys are not looking for tremendous power. 5 - 9 psi and they are happy, unless it is Omarboy, or the guy I am trying to convert to big boost, pgmike (or myself for that matter).
benIX
Nov 26, 2016 07:58 AM
benIX
Oct 16, 2016 11:28 PM
3bar_dc2
14
Aug 20, 2016 10:12 AM
EvO_essence
12
May 9, 2016 12:48 PM
Derek888
14
Feb 13, 2006 07:45 PM
