Exhaust Gasket (where to buy?)
Old Apr 15, 2005 | 06:08 AM
Kelspar's Avatar
Did a search; i used to get mine from Ptuning.com but now i cant find it on their site. Does anyone know anyone who knows anyone (just kidding) who knows where to get replacement gaskets? I need the down pipe-header one, two flange ones and one rear exhaust. Possibly a header one as well. But if the dealer is the only place to go, so be it. I just thought i would see if anyone had found a supplier. thanks!
-heath
Old Apr 15, 2005 | 08:53 AM
Guru_Del's Avatar
i have never replaced my gaskets and i have taken the header off many times. i was turboed so i took it off to install that, then put a header on and did that then went back to stock so in all about 4 or 5 times and never replaced the gasket. In theory you should be fine, however if you know you need a new one and you are talking about the little one on the bottom of the exhaust manifold go to a muffler shop they will have them, they are just a 2 bolt gasket.
Old Apr 15, 2005 | 06:49 PM
Blacksheepdj's Avatar
Go to AutoZone/Pep Boys/etc and ask for a 1.8L Mirage exhaust gasket. It fits (maybe a little tight on the bolts, but it fits).
Old Apr 15, 2005 | 07:34 PM
rcefstsfecr's Avatar
try rockauto.com good cheap place to get OEM parts for any car.
Old Apr 16, 2005 | 02:36 PM
Kelspar's Avatar
Anyone know what type of gasket for Downpipe to rrm header? and do i use stock down pipe? thanks.
Old Apr 17, 2005 | 12:04 PM
Yes, you use the stock downpipe. Or if you'd like to upgrade that too, either get a custom one or buy the Buschur downpipe.
