Oil Pressure Gauge Help!
Old Apr 15, 2005 | 06:10 AM
OZLancer1's Avatar
I want to install my megan oil pressure gauge. I've been searching the forums for some help and found that I have a few options. I know that I could tap into the hex bolt right above my oil filter, but I have my turbo oil feed line there. Can I tee that off and attach my sending unit there? If I can, what size is the fitting for the oil feed line so I know what size tee to get? My sending unit uses the standard 1/8" and I was hoping that the oil feed line is the same size so it will make getting a tee easier. I don't even know if they make tees with different size threads on either side. I would appreciate any help anyone can give. Thanks!
Old Apr 15, 2005 | 09:53 AM
krnzzang84720's Avatar
i tried to install auto gauge oil pressure, but the sending unite never fitted because of different thread!!! if you do get it install please write us a "how to" on OZ
Old Apr 18, 2005 | 06:38 AM
OZLancer1's Avatar
bump
