header downpipe install
Old Apr 17, 2005 | 04:23 PM
hypo74's Avatar
Angry header downpipe install
got all the bolts off the header and everything was going ood. i was unable to get the two bolts off the 2nd cat to drop it all in one piece. it was a real pain in the f''''n ***. i wound up putting everything back together again and wasted my day. i plan on heating them next time, the bolts after the second cat, and basically burning them off the freekin thing. anyone got any better ideas. i had all the right tools. Airgun etc.....
Old Apr 17, 2005 | 04:25 PM
twardnw's Avatar
there's a great product called PB Blaster, best thing for helping free up stuck nuts and bolts. Get a can of that, and spray the hell outta that nut, then let it soak for a while (hour or so), then have at it
Old Apr 17, 2005 | 04:28 PM
pgmike's Avatar
i find the best way to use the pb blaster is to spray it and let it soak and then knock the bolt a little and spray again and let it soak and see if it comes off, repeat until it comes off
Old Apr 17, 2005 | 06:47 PM
GreenPsycho's Avatar
or if your swole like me, just bust out the regular 17mm box wrench and give it a tug
Old Apr 17, 2005 | 09:44 PM
Kelspar's Avatar
what i did was get a wrench; put it on and stuck my foot under the card (on the wrench) and pushed the hell outta it; it broke free pretty easliy
Old Apr 18, 2005 | 06:46 AM
blaze_125's Avatar
Isn't that bolt a 16mm though Cause I got mine off with a 16mm Snapon
Old Apr 18, 2005 | 06:54 AM
don't believe so, i could swear is 17mm, just took it off saturday cause i had to drop my dp to do my IM swap
Old Apr 18, 2005 | 07:01 AM
Kelspar's Avatar
Not trying to hijack thread but since we are on dp/header topic. Does the rrm header bolt to stock downpipe? if so where can i get the gasket for it? the hardest thing for me was taken the damn o2 sensor of the cat lol.
Old Apr 18, 2005 | 07:12 AM
yes, rrm bolts to stock downpipe, but i wouldn't keep the stocker for long, try to get a buschur dp and you'll be doing much better
gasket? i forget what shape/size it is, best bet is stealership
Old Apr 18, 2005 | 07:55 AM
Kelspar's Avatar
stealership
no doubt......you know those plastic screws for your wheel liner? 1.47 / piece
Old Apr 18, 2005 | 09:45 AM
sthiewes's Avatar
Sorry if about going off topic but....
went to dealership to see how much that carbon fiber dash piece was (like what the ralliart has)....he told me $255 because it was a special order...give me a break, may as well just order that 16 piece carbon fiber dash set. Just had to tell you guys about that...
Sorry about that, Back on topic now...
