sparkplugs and wires?
Old Apr 27, 2005 | 06:30 PM
onebadmitz's Avatar
sup everybody.. I was just wondering do yall think that new spark plugs and wired are worth it.... If they are what kind would be a good choice..
Old Apr 27, 2005 | 06:33 PM
SLVROZ_03's Avatar
Well... can't go wrong with NGK's, plat/irid/etc. All good, but wires...I don't see them necessary unless you've a bump'n sound system, or just going for that aftermarket look. Seen many Lancers with turbo with just OEM wires too. But...it's up to you. Good luck.
Old Apr 27, 2005 | 06:37 PM
onebadmitz's Avatar
yeah i got a system and im just lookin for the best choice....
Old Apr 27, 2005 | 06:43 PM
ambystom01's Avatar
Supposedly it can help idle, but they're like grounding kits, some people say the work others say they don't.
Old Apr 27, 2005 | 09:37 PM
03RallyLancer's Avatar
i got the ngk iridiums and the ngk spark plug wires... i like them both... i have no complaints... and it does seem to be a lil bit smoother during acceleration... maybe my plugs were just getting old. but that just my .02
Old May 11, 2005 | 09:55 PM
MY2003OZ's Avatar
Registered User
i've heard they help, but you cannot take the cheap route
Old May 12, 2005 | 12:04 AM
HobieKopek's Avatar
Don't bother. Unless you need to upgrade your ignition due to need for increased spark or faulty wires or plugs you really aren't going to "get your money's worth". If you want to change your plugs it's not going to cost you much, so have a blast, but wires are really intended for those who need a better spark because of shortcomings in the ignition system or faulty/degraded stock wires.
Old May 12, 2005 | 10:16 AM
Blacksheepdj's Avatar
How many miles are on your car? You do need to change the plugs periodically!
As for the wires - it's one of those "couldn't hurt, but you don't need to" mods. Unless you're not getting proper spark. Then, it's more of a "go for it" mod. But with a 2003, I doubt your wires are dying yet.
Old May 12, 2005 | 10:22 AM
Archangelite's Avatar
isnt it more for force fed lancers?
Old May 12, 2005 | 10:26 AM
Well, they say that bigger wires can provide more spark for F/I cars, but of course there's no solid #s to back that up. It's just kinda like "we said so."
Old May 12, 2005 | 12:50 PM
HobieKopek's Avatar
The only reasons I got Mangecors it was because the silicone coating withstands heat better than rubber coated wires, and I wanted the blue to match my engine bay. I haven't gotten to take the car out yet (surprise surprise), but just idling and revving I noticed zero difference.
Old May 12, 2005 | 06:32 PM
i thought magnacores are red? the ngk's are blue though
Old May 13, 2005 | 12:25 AM
HobieKopek's Avatar
Depends upon the diameter of the Magnecors. The 7mm are red, the 7.5 are blue, the 8mm are red. At least that's if I remember the measurements correctly. It's definitely red, blue, red.
Old May 13, 2005 | 10:36 PM
KillahB's Avatar
All spark plug wires do for you is keep the spark output at an optimal rate longer than OEM plug wires. The is no performance gain, but less of a performance loss (if that makes sense) over time.
