Intake/exhaust Valves
Old Aug 7, 2005 | 07:20 PM
Supa tek's Avatar
I took the valves out of the head and cleaned them up and they are black. Are the vales in the heads coated with something for heat or anti-corrosion?
Old Aug 8, 2005 | 01:14 PM
gregivq's Avatar
yes
Old Aug 8, 2005 | 01:18 PM
Alchemist's Avatar
is this another thread or was my response deleted?
I don't believe they're coated with anything. They are case hardened, so the hardness is only about 1/16" deep- you don't want to scratch them. I use a brass wire wheel on my drill to remove the carbon deposits and they have a greyish finish when I'm done. Stainless wheels are too strong and would probably scratch off some of the case hardening.
you could also soak them in something like techron (available by the gallon at some parts stores) it's the buildup remover that Chevron has been using for decades. A nice soak and then brushing by hand (again brass or maybe a hard bristle toothbrush).
Old Aug 8, 2005 | 01:35 PM
gregivq's Avatar
Intake valves dry film lubricant such as DFL-1, TLML, or CERMA LUBE.
Exhaust valves thermal barrier CBC2 or CBX and then dry film lubricant DFL-1, TLML or CERMA LUBE.
I'm not sure if that applies to every vehicle.
Black_EVO_MR
Nov 9, 2016 05:10 PM
piponpi
Sep 9, 2016 07:33 PM
Arrrrgh
Aug 22, 2015 04:26 PM
Miasma987
Aug 23, 2013 10:05 PM
Hot Wheelz
Nov 21, 2008 12:21 PM
