Radiator hoses
Old Oct 6, 2005 | 08:03 PM
Blacksheepdj's Avatar
Won't fit. I've done the research here. Hoses are setup different. Different part #, also.
On the other hand, it's just silicone hose. If it's close enough, you could try to stretch/squish it into place...
PS - since I had a whole thread on it, I'm going to do it. Search, n00bs!
Old Oct 7, 2005 | 06:21 AM
gregivq's Avatar
Cool blacksheepdj, cough, noob, cough. If it doesn't fit, cut it, strech it, do what it takes, LOL.
Let us know.
Old Oct 10, 2005 | 04:28 PM
omarboy25's Avatar
the evo and the lancer have the same exact radiator but only the bottom hose will work i ordered the koyo radiator for the evo its a perfect fit
the upper will not fit if i am not mistaken
Old Oct 10, 2005 | 09:11 PM
gregivq's Avatar
Is it too short? It sux, does anyone know where I can get the braided steel ones?
Old Oct 10, 2005 | 09:28 PM
HobieKopek's Avatar
Actually I think it's too long. If you're going to use real braided steel well...1. it's probably going to cost a fortune and 2. You can just buy a length of it and cut it to the needed length. I don't think the bend is essential to flow, but you obviously don't want it kinking when the engine torques.
Old Oct 10, 2005 | 10:13 PM
gregivq's Avatar
If it's too long you can cut it and make it fit right? I did see couple of OZs with steel braided hoses. It didn't look that great but as long as the performance is there.
Old Oct 10, 2005 | 10:21 PM
HobieKopek's Avatar
I've only ever seen braided SS sleeving kits for the Lancer. If there's a true SS hose kit it'd be expensive as hell, because that **** costs about $20 for a 3' section in '10AN (which is about 1/2-5/8" ID. I forget exactly.) At 1 1/2-2" it'd cost a ****ing fortune.
Old Oct 17, 2007 | 07:13 AM
Juan Martinez's Avatar
You can also just cut it, get some clamps and a metal insert and mate it to another hose.
