Ok here's the scoop
Old Dec 12, 2005 | 07:10 PM
newbiewonkenobe's Avatar
Lightbulb Ok here's the scoop
Here's my plan, with one final question. When it comes to my 05 exhaust here's my plan:
rpw race headers/downpipe
RRM high flow cat (don't want to lose too much low end torque)
rrm's axle back exhaust.
***I want everything to be as simple (AKA BOLT UP) as possible, will the above set up cover me? Or am I missing some gaps? Thanks again guys. Take care.
Old Dec 12, 2005 | 07:31 PM
Johns Slow ES's Avatar
unless u plan to use the stock mid-pipe then yea u got everything
if not then instead of the axel back get the catback from rrm or where ever
Old Dec 12, 2005 | 07:32 PM
twisty1251's Avatar
the RRM high flow cat doesn't bolt up to 04-05 lancers. that part of the exhaust is different from the 02-03
Old Dec 12, 2005 | 07:46 PM
rhyzin's Avatar
if he got the rpw header, than the HFC cat should be a fine add on. he will need something to take the place of the cat if he gets a header designed for the 02-03.
Old Dec 12, 2005 | 08:13 PM
ok so it seems I'm all ok except for the mid pipe length. RRM (nor anyone, as far as I know) sells a catback for 05 es. any other thoughts?
thanks again!
Old Dec 13, 2005 | 12:23 AM
akasirlancerlot's Avatar
CUSTOM. get yor header, go to a shop and get a custom header back.
Old Dec 13, 2005 | 07:36 AM
NateOZ's Avatar
The downpipe of the 04+ is welded to the second cat, which is why the high flow wont bolt up. You would have to cut and have a flange welded at an exhaust shop, or get your hands on an 02-03 downpipe. From what ive seen the 02-03 downpipe would bolt up to the stock header, and leave u with a flange on the other end. Should work, when i got my header on i noticed the downpipe ended right before the cat started.
Old Dec 13, 2005 | 08:21 AM
Blacksheepdj's Avatar
Not to be mean, but what part of RPW header didn't you understand?
The RPW has it's own downpipe...
Old Dec 13, 2005 | 10:08 AM
NateOZ's Avatar
missed it sorry, guess i was thinkin too fast. Well if thats the case, wouldnt the RPW bolt up to the RRM high flow. As long as he put both on at the same time there shouldn't be a problem. Oh and 1 more thing, the RRM axleback hangs low on 04+, fyi. This is just thoughts, in attempt to be helpful.. be gentle .
this might help him out too https://www.evolutionm.net/forums/sh...ght=RPW+header
Old Dec 13, 2005 | 10:36 AM
Yeah, the RPW header/DP and RRM HFC should mate perfectly. So he just needs to slap on a catback and he'll be rockin'.
Old Dec 13, 2005 | 09:30 PM
03RallyLancer's Avatar
we would have to get someone in here that knows... but i thought rpw ended in 2.5? or is theirs 2.25 also?
Old Dec 13, 2005 | 09:50 PM
rhyzin's Avatar
nope. RPW piping is 2.5". the RRM is 2.25". but in terms of everything fitting under the car, yeah it fits fine unless exhaust mounting points have changed.
Old Dec 13, 2005 | 09:53 PM
then instead of changing sizes... through out your exhaust 2.5-2.25-stock-2.25 why not just get a high flow cat from rpw and then get a custom exhaust to match... it will cut down on your pipe changes... and you dont loose that much low end... im running rrm header, buschur dp, buschur hfc, and buschur catback
Old Dec 13, 2005 | 10:02 PM
rhyzin's Avatar
nice setup. your setup is much more ideal and is what people should be gunning for.
if someone would get their *** down to RNR in socal, they said they were interested in making a 2.5" exhaust. our only supplier of 2.5" WAS buschur. no more.
Old Dec 13, 2005 | 10:07 PM
well if i would have planned my setup more i would have gone rpw header/dp with buschur hfc, and catback... but when i got it, i wasnt as learned about rpw as i am now, which is why i try to get their name out as much as possible and when the chance presents its self
