arcing problems + a relapsing misfire
Old Feb 5, 2006 | 03:05 AM
HobieKopek's Avatar
Originally Posted by comatose721
so far the colder plugs are working out a little bit better.
Thought that might help, but I'm still a little concerned about the oil thing.
Old Feb 5, 2006 | 05:59 AM
comatose721's Avatar
the rubber gaskets between the valve cover and the spark plug well were not making a proper seal. i put a small amount of RTV silicone around those areas and let it dry with the rubber ring on it to make sure no more oil is blowing through. one plug has also wiggled itself loose and oil blew up from the combustion side...that is the one that i was concerned about the most. i need to check everything again now that i have been running it for a week without any problems.
Old Feb 6, 2006 | 12:26 AM
HobieKopek's Avatar
Awesome. Glad you got that solved. When are you coming to the dark side?
Old Feb 6, 2006 | 05:22 AM
the dark side i'm not so sure what you mean by that. sorry i'm dumb. can you clarify? thanks.
Old Feb 6, 2006 | 06:21 AM
gregivq's Avatar
^Forced Induction side!
Old Feb 6, 2006 | 08:47 AM
hopefully by the end of the summer. i'd like to have the turbo broken in by the first week of october. then i can hit up the track and dyno day at CNFX all in one weekend before it's too cold.
Old Feb 6, 2006 | 09:33 AM
HobieKopek's Avatar
Hope so. Good luck!
Teal2nnr
Feb 25, 2017 10:55 PM
fuzzycuffs
Feb 23, 2017 11:20 AM
mrhussain
24
Feb 16, 2017 08:01 AM
Raceghost
Oct 10, 2011 04:34 PM
devolutiongsr
13
Sep 26, 2010 06:07 PM
