what you buy with $2000 in N/A mods
What are the realistic gains with $2000 in N/A mods?
i know that for a thousand or two more, one can go for a turbo or sc, but in the case if someone were to stick stricly with NA modifications, how much of an increase in whp/torque can they possibly go with stock internals
Let's say that for roughly 2000, you go the practical NA route..you can get yourself...
catback 350
intake 180
header 360
piggyback v.2 460
t/b 300
hi-flow cat 100
IM 350
crank pulley 100
realistically, how much whp can one get from the above mods.
and YES, i know that going turbo or sc will give greater improvement. that's a given, so please don't reply "JUST GO TURBO". If in the case someone did happen to go NA for whatever reason, from your guys' experiences, what would be the whp gains.
also, if you all can give your estimates on 1/4 times for each in auto and manual
thanks in advance
catback 350
intake 180
header 360
piggyback v.2 460
t/b 300
hi-flow cat 100
IM 350
crank pulley 100
thanks in advance
Those numbers I posted are the HP limits for the NA 4g94. The mods you listed will fall short of that number. The numbers would be even lower for an automatic.
To achieve those number (~160-170) you would also need a custom tune, rather than a generic piggyback map to try and squeeze all the horses you can out of it, the phenolic spacers, upgraded camshaft, port and polished head, higher compression pistons (10.5:1), and perhaps an FPR.
I would say maybe 120whp. Realistically intake gives maybe 1-2 hp, header, say 5-6, exhaust, 2-4, cat, 1-2, IM and TB, 10 together, crank pulley, nothing just increases response and piggyback like 15. So thats 24 hp gain, and thats assuming they all add to the same part of the powerband, which they don't. I don't know why people are so obsessed with having the highest horsepower numbers, the shape of the curve is far more important.
Yeah i was only saying 130 tops if you take this upgrade path bellow.
Header & Down Pipe
High Flow Cat
Cat Back
Intake
Underdrive Pulley
Road Race Plug Wires
Bored Fuel Rail
Intake Manifold
Aluminum Flywheel / (Manuals)
PIGGY BACK ECU / Customed Dyno Tuned
Throttle Body
CF Hood
Light Weight Rims
Driver that weighs under 120lb
Header & Down Pipe
High Flow Cat
Cat Back
Intake
Underdrive Pulley
Bored Fuel Rail
Intake Manifold
Throttle Body
CF Hood
Light Weight Rims
Originally Posted by saecoes
130whp for an AT, or both AT and MT?
