header making nose
Old May 4, 2006 | 08:31 AM
Blacksheepdj's Avatar
Snap crackle pop - unburned gas going poof in the exhaust. Gotta lean that ***** out!
Ever since I put the GReddy canister ($79 at RRM! ) on my Subaru, I always hear the pops. Just part of having an exhaust on a car not tuned for it.
Old May 4, 2006 | 03:04 PM
civilrage's Avatar
i dont pop piggyback and rpw header ftw.
Old May 4, 2006 | 03:11 PM
twisty1251's Avatar
yep, no pops here either...FTW!
Old May 4, 2006 | 04:32 PM
Handmemyarms's Avatar
i pop if im coing down from a high rev in neutral, its natural, i know its just back pressure, i think it sounds b!tchn
Old May 4, 2006 | 06:28 PM
Elvis's Avatar
mine pops to since the header, but never did it with just the cat back.
Old May 5, 2006 | 05:52 AM
oz4g94's Avatar
mine will pop a lot if i let off of the throttle in a gear too high for the revs, usually 1500rpm in 3rd
Old May 5, 2006 | 06:30 AM
comatose721's Avatar
right now mine is poping throughout the whole RPM range
....ooops i forgot, only 3 cylinders are firing AGAIN
Old May 14, 2006 | 02:50 PM
turboslik's Avatar
Mine does it too but it's kinda quiet...everything is stock on mine though...
Old May 14, 2006 | 05:47 PM
and there you have it folks
Old May 15, 2006 | 08:08 AM
N1te's Avatar
something spark plugs something and wires something
Old May 15, 2006 | 09:08 AM
spark plugs were covered in gas, both coil packs are good (replaced one anyway), plug wires were fine, compression was fine.......i fried that huge wiring harness that runs from the battery->fuse box->trans/cam position/o2 sensor/fuel injectors/crank position sensor/egr syste,/etc....the wiring harness with all of that in it yeah well it melted and fused together. the lack of ground caused cylinders 1 and 4 to not fire.
Old May 15, 2006 | 10:34 AM
N1te's Avatar
Sorry I didn't realize you were this guy
but I'd recommend to stop trying external combustion on your engine.
Old May 15, 2006 | 11:13 AM
ROCK's Avatar
Mostly normal, especially if you have no cat or a test pipe etc...
ROAD/RACE
Old May 15, 2006 | 06:54 PM
that is the most ridiculous thing i have ever seen N1te
Old May 15, 2006 | 08:04 PM
N1te's Avatar
lol i know but how did everything melt?
