4g93 pulleys for 4g94 lancer
Originally Posted by CoastieOZ
okay i searched and couldnt find, so i come to the experts for advice, will the crank pulley for a 4g93 (97-01) mirage fit a 4g94 lancer? if so any belt probs, any info would be greatly apreciated. thanks oh lancer gurus.
http://cgi.ebay.com/ebaymotors/Light...QQcmdZViewItem
Originally Posted by Gungrave
Yes the 4g93 pulley fit to the 4g94 are the same,belt are the same too
Originally Posted by comatose721
as far as i know the belts are not EXACTLY the same. the accessories are not set up identical to the 4g94 (atleast that is what i have read). there should be some small differences in belt size.
if you refere to the time belt yes is no the same ,but the belt for the alternator is the same but the power steering is a little bit longer
btw, pulley is scheduled for delivery on the 15th
mark
i know that the generator belt is identical and also that the timing belt and drive belt are different sizes on the g93 + g94
my problem is finding a drive belt that will match up with the UDP once it's installed on the g94. do you know of anywhere i can find a decent picture (preferably shop pic) of the 1.8L Mirage accessories set up? i've been searching the mirage forums and doing some google image searches but haven't found anything productive. i may just try the belt that is recommended for the mirage if it looks close enough
mark
mark
nope; i've been to busy being a fish and surfing every minute that i'm not in work or partying at night. with this weeks pay check i'm going to buy some belts to play with. i have the pulley sitting on my bench though....it's getting pretty lonely.
this whole belt deal is just turning into a headache. i'm hoping the belt recommended for the mirage will fit (though i know most likely it won't).
UDP has been installed and the lancer runs great. here are some pic's. i'll do a write up on it later.
Drive Belt # 5050490-5PK1245
Alternator #5040285-4PK0725
check out the difference in size
...now it's time to go kill some gas and have fun with this thing...
mark
mark
Originally Posted by Alchemist
compared to the lightweight pulley how's the power? I asked in the other thread, too, but where'd you order from?
