RPW Camshafts
Old Apr 24, 2003 | 12:19 AM
02Lancer's Avatar
i was just saying that some people may feel that a $4K turbo kit or a huge spoiler would be considered unecessary
i feel if your looking to make a more respectable hp # in a n/a lancer i think you'll have to step up to the stage 2 grind and add the necessary mods to make it run well. so far i have been a little dissapointed in power gains on the lancer thus far and think that the stage 2 cam may provide some really good numbers while the stage 1 will fall short, but i guess i'll just have to install one or wairt U9V puts his in
Old Apr 24, 2003 | 12:23 AM
02Lancer's Avatar
you only need a stage 2 if your going turbo
well, RPW has a stage 1, stage 2, and stage 3 grinds for N/A motors and then a cam with profiles for a TURBO motor so i'm not seeing how a stage 2 might only be necessary for a turbo application
also if you bolted on a CAI, SAFC w/fuel pressure regulator to bump up the air/fuel being fed to the motor, wouldn't that be enough to satisfy a stage 2 cam? if not how much do you think you would really need? ported throttle body perhaps?
Old Apr 24, 2003 | 08:18 AM
neilschelly's Avatar
I've always been very impressed with RPW's site. They are very specific about exactly what comes with every package they sell, exactly what uses it's intended for, and exactly what other upgrades should be done alongside each of theirs. If you read their site, this won't be a question.
-N
Old Apr 24, 2003 | 08:59 AM
uranium9v's Avatar
Here are the specs on my stage 1 cam:
Inlet
Lift .371
duration 258
Exhaust
.36
duration 248
This is all at the recommended timing of .004 Camlift. I think you guys would be impressed with the stage one.... it's actually a very close grind to the Migare stage 2.
Old Apr 24, 2003 | 09:02 AM
airlinevomitbag's Avatar
U9V Only you can stop the madness and get this thing done. No more speculation.
Old Apr 24, 2003 | 10:25 PM
lanceroz84's Avatar
yes really uranium can you drive by road race and get Rob to help you out I mean you are in Cali just my 2 cents
Old Apr 25, 2003 | 12:55 AM
M3 STYLELAB's Avatar
he's like what only.... 6 hours away from RRM !!!
modesto is far..
Old Apr 25, 2003 | 01:14 AM
02Lancer's Avatar
-N
i was directing that question to zlancer because he feels we would need a lot of air/fuel being fed to the motor for a stage 2 cam. i think all of the things that i listed above (which RPW recommends) would be more than enough to handle the stage 2 cam. i was just looking for zlancers suggestions, sorry for the confusion
Old Apr 25, 2003 | 01:20 PM
fury656's Avatar
After a few phone convos with vision ive decided upon my setup, any suggestions would be appreciated
RMR Intake
RPW Header
RRM Bored Throttle Body
Greddy Evo Exhaust
RPW Fuel Pressure Regulator
Greddy E-Manage
RPW Stage 2 Port & Polish
RPW Stage 2 Camshaft
RPW Cam Gear
RPW Valve Springs
Old Apr 25, 2003 | 01:30 PM
reddog's Avatar
RMR Intake
RPW Header
Greddy Evo Exhaust
Greddy E-Manage
RPW Cam Gear
RPW Valve Springs
Out of curiosity, do you plan to do the work yourself, or have a shop do it for you.
Old Apr 25, 2003 | 01:34 PM
fury656's Avatar
Shop, my automotive installation abilities dont go past installing headlight bulbs...
Old Apr 26, 2003 | 12:50 PM
WADADLIG_OZ's Avatar
You'll have to send your stuff to RPW to have it ported and polished. You better have 2 cars for that so you won't be out of wheels.
WADAD
Old Apr 26, 2003 | 12:55 PM
fury656's Avatar
They have an exchange policy on the heads.
Old Apr 26, 2003 | 07:54 PM
KMcW's Avatar
Well that set up sounds badass, let us know how it turns out.
One thing though, why not go with a cold air intake?
Old Apr 26, 2003 | 09:19 PM
Smoktout's Avatar
also, you might want to look into the RPW throttle body as it is a few mm larger than the RRM one.
