RPW Camshafts
Old Apr 26, 2003 | 10:26 PM
  #31
redbeard's Avatar
Where is the RPW tb available? I don't see it in Vision's site, just the quad tb.
Old Apr 26, 2003 | 10:30 PM
  #32
Stumpy221's Avatar
im pretty sure if you ask them about it, they will be able to get it for you
Old Apr 26, 2003 | 10:31 PM
  #33
Smoktout's Avatar
im pretty sure it's available through RPW...maybe check their website or shoot them an email.
Old Apr 27, 2003 | 05:34 AM
  #34
Mitsiman's Avatar
Camshafts
Good to see a lively thread with lots of information.
To clarify some information for everyone.
There is no reason why you cannot use a stage 2 camshaft. To give an example we finished a 1.8 mirage the other day with stage 1 camshaft, 55mm tb, FPR unit, RPW race extractors, exhaust, greddy emanage, cold air induciton kit and got 125hp at the front wheels thats 125kw at the flywheel.
You can all imagine then what we can get form a 2.0 lancer with the same mods and a larger throttle body.
The point being a bigger camshaft is not always better. I really recomend for the majority of people who only use the car for city driving etc the stage 1 camshaft will always improve powre everywhere as well as more torque. The stage 2 cam is larger and whilst it does work even better, it won't start producing the same power as a stage 1 till around 3000 - 4000rpm and for a normal street car that can be bad unless you drive in those rpm levels all the time.
You do have to have valve springs for a stage 2 camshaft because the higher lift and duraiotn will cause the stndard valve springs to not be able to crush enough and valve bind and the cam gear is to allow you to set the cam timing up more accuratly but is not necessary.
With regards to throttle bodies yes we do the htrottle bodies for the lancers - as per our website but it is a fairly long time process with the USA as ou have to send us yours first and then we send you one back.
David Thomas
www.rpw.com.au
Old Apr 27, 2003 | 10:13 PM
  #35
fury656's Avatar
My reason for wanting to go with a stage 2 cam is mostly due to the fact that this car is basically dead up top. To me with the mods surrounding the stage 2 cam the losses in the low end will be nominal when compared to the gains where the car needs it the most.
Old Apr 28, 2003 | 02:13 AM
  #36
Mitsiman's Avatar
Good reasoning and something that individual drivers need asses before modifying the car. THis is why we give options and recomendations but ultimatly it is up to the customer to decide dependant upon how they drive there car and wehre they want to drive the car.
David Thomas
www.rpw.com.au
Old May 13, 2003 | 11:57 AM
  #37
Salvalus's Avatar
How Much Do Those RPW Parts Cost In US Currency??
(Throttle Body, FPR, Stage 2 Port & Polish, Stage 2 Cam Shaft, Cam Gear, Valve Springs).
Plus You Need AFC And More...
Sounds Expensive...
Woo Hoo My Member No. Rocks Muhahaha !!
Old May 13, 2003 | 12:06 PM
  #38
ryancb's Avatar
contact vi for prices
Old May 13, 2003 | 12:17 PM
  #39
uranium9v's Avatar
The 1.5 cam I have is all about top end and mid power. You don't need to go stage 2 to get it back, 1.5 is awesome, don't know about the stage 1 though. I've been in a Tiburon with a stage 2 cam and it really seemed to bog in the lower RPM's, but was quick as hell past 3.5k
DirtyRalli
Jun 24, 2013 05:49 AM
DirtyRalli
May 1, 2013 07:27 PM
Carrier
Lancer Engine Tech
May 12, 2007 11:34 AM
redozrally
Jul 23, 2006 03:02 PM
2wdSQL
Lancer Engine Tech
Apr 10, 2002 09:59 PM
