04-06 Ralliart Engine/Drivetrain (no forced induction)
Stage 2 rpw valve adjustment
Old Apr 30, 2013 | 08:49 AM
DirtyRalli's Avatar
Hey guys so this week my stage 2 rpw N/A cam and camgear is going in and my mechanic is asking me about the valve adjustment ...will i need to adjust it? If i do does anyone know the measurments?
I tried searching but wasnt successful...Any help would be appreciated im kind of in a rush
Thanks in advance!!
Old Apr 30, 2013 | 09:24 AM
bakuro117's Avatar
Im not 100% sure if its the same with a different cam but the stock valve adjustment should be:
Intake valve: 0.008 inch or 0.20 mm
Exhaust valve: 0.012 inch or 0.30 mm
Im about to do mine this weekend so Ive been reading up on it.
EDIT:: BTW I was wondering if anyone knew of a decent video showing how to do this procedure. I want to have seen as much of it as I can before I attempt to pull it off this weekend.
Old Apr 30, 2013 | 09:39 AM
DirtyRalli's Avatar
Ohh ok thats good to know but i think it should be bigger for a stage 2 cam if im not mistaken
Old Apr 30, 2013 | 11:19 AM
bakuro117's Avatar
I could be wrong, but I would think that the changed lobes of a cam would be what alters how the valves lift, not the initial lash adjustment. I'm sure someone with more cam experience will pop in and educate us soon though.
Old Apr 30, 2013 | 12:22 PM
lanzerralliart's Avatar
EvoM Super Moderator
I would call RPW since its their cam they would know best
Old Apr 30, 2013 | 10:45 PM
CrAnSwIcK's Avatar
lash should be the same, but like bakuro said, with the new cam, they will all need to be adjusted...the lash is the gap between the rocker arm and valve stem too little and valves may not close completely when the engine is hot, too big and it will sound like a diesel. i can't see why changing the cam would require a different lash...
Old May 1, 2013 | 04:49 AM
DirtyRalli's Avatar
I just contacted rpw and they said to use the factory specs... So i assume the hot to adjust valve lash thread is correct?
Old May 1, 2013 | 07:26 AM
bakuro117's Avatar
Yup. If that's the case then its the same specs as above or in the 'How To Guide' set them while the engine is at operating temperature. Let us know how that cam does. I looked them up yesterday after seeing this thread, very interesting.
Old May 1, 2013 | 07:27 PM
DirtyRalli's Avatar
yeah im really excited to see what numbers ill be getting on the dyno... Especially with the hackish tune
drucea
Oct 2, 2017 08:26 AM
DirtyRalli
Jun 24, 2013 05:49 AM
4g94T
Lancer Engine Tech
53
May 30, 2010 01:38 AM
4g94T
Lancer Engine Tech
18
Nov 3, 2008 09:01 PM
krimson_binome
Lancer Engine Tech
11
Aug 12, 2005 05:54 AM
