fuel pump
Old Jul 10, 2006 | 05:00 AM
nextgenerationx's Avatar
fuel pump
ok, i'm swapping out my walbro 255 fuel pump and putting the stockers on back on. can someone help me locate where the fuel pump is and how to do the install? is it simple? thx
Old Jul 10, 2006 | 07:59 AM
comatose721's Avatar
pull out the back seat. there is a black plate with 4 screws on the drivers side (rear). remove the screws and the plate --> your fuel pump and fuel filter are located there.
Old Jul 10, 2006 | 01:34 PM
Sicktght311's Avatar
Theres a sticky in the how to installations forum. Check it out. Its real easy, just make sure everything is back in tight and snug. Also its a PITA getting 2 or 3 bolts off holding the fuel pump assembly in cuz they are under a metal panel. I just took a pair of heavy duty pliers and bent the metal up, then bent it back when i was done
