Cheap engine swap for you guys.
Old Apr 29, 2003 | 10:56 PM
Jimb0's Avatar
http://www.boostaholic.net/phpBB2/vi...ighlight=mivec
You could easily turn around and sell the mirage and the mods for 3k, just swap the engine into your lancer. The engine should bolt right in using the 4g94 engine mounts assuming the 4g93(1.8l mirage motor) and 4g94 engine mounts are the same.
edit: It makes somewhere between 160-180hp, I cant remember.
Old Apr 29, 2003 | 11:03 PM
Iamkar33m's Avatar
Hmm, but it says in the post that the engine is seized. They ran it on low oil, means it'll have to be fixed.
Old Apr 29, 2003 | 11:05 PM
Jimb0's Avatar
hes talking about the original mirage motor.
Old Apr 29, 2003 | 11:15 PM
dsmrider21's Avatar
How hard would it be to get a 5 speed for the mivec engine, it's an at tranny, why would you swap in an at tranny??
Old Apr 29, 2003 | 11:38 PM
bahamut's Avatar
Since the G94 uses the same tranny as the G93. It will work since mitsu designed all 4g9x to uses the same flywheel.
Old Apr 29, 2003 | 11:54 PM
OZevoVII's Avatar
errrrr.....cant you get a MIVEC engine from vision imports?
Old Apr 30, 2003 | 12:11 AM
bahamut's Avatar
Through vision, it'll cost you more than an arm and leg and the wait out of Aussie.
