Cam Gear
Old Aug 23, 2006 | 08:57 AM
TougeOZ_04's Avatar
Cam Gear
http://cgi.ebay.com/ebaymotors/Fidan...QQcmdZViewItem
does anyone else have this?
Also would you recommend me and my friends installing this or take it to a shop.
i'm also gettin the RRM cranky pully, should i feel a good gain?
my mods now is SRI, Custom Catback
Old Aug 23, 2006 | 09:28 AM
drucea's Avatar
its fidanza and its all good and cheap. that doesnt do much without a camshaft. but you can still get it. the rrm crank pulley doesnt add horsepower but frees some up so the car revs faster. both dont cost much though so go ahead.
Old Aug 23, 2006 | 09:30 AM
TougeOZ_04's Avatar
is it hard to install a cam gear?
Old Aug 23, 2006 | 09:55 AM
SLVROZ_03's Avatar
Nope, just watch the timing...
Old Aug 23, 2006 | 10:26 AM
TougeOZ_04's Avatar
what tools would i need for the timming and retard?
I'm sure he has the tools but want to make sure he has for the day of the changing
Old Aug 23, 2006 | 09:33 PM
DemisedGabe's Avatar
probly should get a cam before u put in a cam gear.
Old Aug 24, 2006 | 10:44 AM
Blacksheepdj's Avatar
This is one of those "if they sell it, it must make me go faster!" mods that ricers buy off eBay (no offense to you, just speaking in general).
You'd be better off using the money for something else. Cam gears are pretty far along on the "tuning tree" of mods. Until you get things like header/downpipe/IM/TB/etc to finish off the breathing mods, you probably don't need to screw with the timing.
Old Aug 24, 2006 | 11:32 AM
TougeOZ_04's Avatar
ok thanks, i'll prob not getting it now, i'm going for the actual cam from RRM, just getting stuff set up for boost
Old Aug 25, 2006 | 10:19 AM
Well, OK, let me change my answer then.
If you're going to buy it and have it sitting around until you install all your turbo/cam/etc parts, then go for it. It'll be another piece of the puzzle.
If you're going to buy it and install it on your mostly-stock setup, then don't waste the money.
That's a better answer.
Old Aug 25, 2006 | 10:51 AM
TougeOZ_04's Avatar
love that answer, but hoprfully RRM will come out with a Cam Gear
Old Aug 25, 2006 | 12:15 PM
SLVROZ_03's Avatar
I had the Fidanza gear (in red) in hopes of getting the RPW cam. But things fell through and my wish didn't come true. Sold the gear to another member on here. But as long as you are going N/A with a cam upgrade or going F/I you just might like having it.
Old Aug 25, 2006 | 02:36 PM
Doubt it. Cam gear really doesn't do too much of anything. Generally, unless Rob thinks it'll make a difference, they don't bother (see also topic: downpipe)...
Old Aug 25, 2006 | 02:38 PM
drucea's Avatar
yeah, really an aftermarket gear is only to advance or retard timing. other than that, they dont do anything.
Old Aug 25, 2006 | 04:25 PM
TougeOZ_04's Avatar
k thanks save me like 130 plus my friends labor WOOT
Old Aug 25, 2006 | 09:09 PM
Evo666's Avatar
isn't the cam gears lighter than stock? you can save some weight, not much but its a start.
