Upgraded to Turbo
Old May 6, 2003 | 01:05 AM
jmw32123's Avatar
Talking Upgraded to Turbo
I just purchased the following for my 2002 Mitsubishi Lacer. (stock for now)
Slim Line Thermo Fan 263mm
Slim Line Thermo Fan 286mm
Turbo Air Outlet Gasket - 3 Bolt
Turbo Air Outlet flange - 3 Bolt
Gasket S1B Single Entry
Air Inlet Flange - GT-28
RPW Turbo Manifold
Garret GT-28 Ball Bearing Turbo 300 - 350 hp
RPW Turbo Dump Pipe 2 1/2" with flex Pipe
GT25 Turbo Drain Pipe Flange
Turbo Drain Pipe Gasket
HKS SSQV BOV
Thermo Shield Sleeve 1/4"
Oil Feed & Water hoses & Fittings
Rising Fuel Pressure Regulator
Rising Fuel Pressure Guage
4 Modified Stock Injectors
Decompression Head Gasket
Greddy Evolution Exhaust
Greddy Profec E-01
Intercooler Kit
Is there anything that I am missing for optimal performance that anyone can think of.
Once I have everything installed I will be dyno testing and posting the results.
Can anyone recomend suspension and springs?
Old May 6, 2003 | 01:11 AM
ROCK's Avatar
How much $?
ROAD/RACE
http://www.roadracemotorsports.com/
Old May 6, 2003 | 01:13 AM
teknotikal's Avatar
tien
Old May 6, 2003 | 01:34 AM
pickleknock's Avatar
yeah, tein, i got em, and love em to death, excellent spring, much better then progress.
Old May 6, 2003 | 01:57 AM
OZevoVII's Avatar
i have progress, no problems...You have the progress springs before you got the teins pickle?
Old May 6, 2003 | 02:03 AM
import_speedzz's Avatar
How much?.. And did you bring your ride to the dyno already?.. Any estimated HP?... And where did you get it installed?...
Old May 6, 2003 | 02:10 AM
nightrider's Avatar
he said his car is stock and the parts are on the way. but anyway HOW MUCH.
Old May 6, 2003 | 02:32 AM
no, but ive driven an oz with progress, the teins are stiffer and arent so floaty, closer to coilovers in firmness. just depends what you like i guess... the drop is nearly the same though.
Old May 6, 2003 | 12:15 PM
OZevo121's Avatar
ive got progress and they arent "floaty" at all. i like em.
Old May 6, 2003 | 12:23 PM
uranium9v's Avatar
I'm thinkin you're gonna need larger injectors and a larger fuel pump....Prob. the GSX pump.
Old May 6, 2003 | 12:33 PM
pisetup's Avatar
Where did you buy all this and how much???
Old May 6, 2003 | 12:37 PM
put some teins on and youll know what im talking about, but im sure they are much better then stock. what isnt?
Old May 6, 2003 | 01:22 PM
adhem_t's Avatar
whats the total price you payed !!!!!
your killin me
Old May 6, 2003 | 01:24 PM
jmw32123's Avatar
Everything that I listed in my initial post cost me $4200. I pusrchased a nice chuck of what I listed from VisionImports.com. All items were priced out using the best sites that I could find. Exhaust, Greddy profec e-01, and intercooler were purchased off other sites. These are the next upgrades that I am still planning to make. Roadracemotorsports.com seems like a prety good place for the purchase of my next upgrades. Autocross sway bar perches.(<----Is this necessary for my new rear anti sway bar?) Front Strut Bar $89. 2200 lbs. Pressure plate $269 and performance Clutch $89. Tein suspension Kit $1190. If anyone knows a better place to order let me know. I will be ordering otherwise tomorrow.
Any other thoughts on the injectors and fuel pump? Anyone else agree. Does anyone have recomendations for a replacement clutch. Thanks for the feedback.
Old May 6, 2003 | 01:31 PM
HobieKopek's Avatar
Could we try to keep this related to engine tech since it's in engine tech and put the suspension questions elsewhere please? It makes things a lot easier to organize when these things are separate.
