Quad TB's + Turbo=??
Old Sep 20, 2006 | 08:47 AM
TougeOZ_04's Avatar
Ok i've been looking at the quad set up for quite some time now, and RPW makes like a shield around it and that opens inone hole.
take a look
http://rpw.com.au/Performance%20Upgr...qaudtb4cyl.htm
the bottem picture
can a turbo setup be done with this? Might need some big pipes?
Old Sep 20, 2006 | 08:51 AM
drucea's Avatar
I have been contemplating this as well but with the twin throttle body. It would be just like normal but I don't know the benefits of a quad tb. Just have a large exit on the turbo with a large pipe coming off splitting into 4 smaller pipes leading to each TB.
Old Sep 20, 2006 | 08:53 AM
drucea's Avatar
Also I looked at that quad setup a while back and can't figure out how it works. Any explainations?
Old Sep 20, 2006 | 10:10 AM
crypto's Avatar
Former Vendor
the turbo can be ran with the quad, but requires rediculous tuning.
there are several threads floating around covering this stuff, here's the one i found most informational
https://www.evolutionm.net/forums/sh...aru+hood+scoop
Old Sep 20, 2006 | 11:28 AM
03RallyLancer's Avatar
you wouldnt split your intake pipe into 4 pipes... you would make a large plenium to feed the ITBs it would kinda look like a log w/ the itbs coming out one end and a giant intake tube running in.
Old Sep 20, 2006 | 01:13 PM
TougeOZ_04's Avatar
i couldn't image how much tunning is need tho? ECU reflash
Old Sep 20, 2006 | 01:26 PM
lol... for itbs... you are going to need standalone... for itbs + boost you definately gonna need a standalone. you are going to have to get rid of the MAF
Old Sep 20, 2006 | 01:27 PM
gregivq's Avatar
LMAO this thread is funny
Old Sep 20, 2006 | 01:32 PM
rhyzin's Avatar
you have to put "Port Injection" in front of ITB, otherwise, it's improper...
yeah i normally dont even reply to threads like this... but i am in a good mood today and felt like humorin some ppl
Old Sep 20, 2006 | 01:58 PM
Blacksheepdj's Avatar
Just run 4 TBs, 4 turbos, and pay your local tuner a couple grand to get it all running. Then pray.
Old Sep 20, 2006 | 02:02 PM
gregivq's Avatar
Haha seems like everyone is in a good mood today.
If you can't understand, and understand meaning after reading about it, how ITB works...then you shouldn't even be thinking about doing anything with cars.
Tuning:
Standalone>Interceptor>Piggyback with sensor (emanage)>ECU Reflash>piggyback (SAFC)>noob.
Old Sep 20, 2006 | 02:12 PM
TougeOZ_04's Avatar
i understand but i didn't kno if a turbo can be added or not
Old Sep 20, 2006 | 02:14 PM
To be honest, I think it's mostly an N/A mod.
Turbo is fine with one TB. It's the N/A people who do every mod available, only added 20 whp, and then look to more adventurous options (like ITB).
You have to get out of the mentality of "if it works for N/A, it'll be twice as good with a turbo" - that just doesn't work.
Old Sep 20, 2006 | 02:24 PM
rhyzin's Avatar
unless you're a bugatti veyron.... mmmmm...
PIITBs and turbo together is just a little over the top for normal people, esp when they cost about the same depending on the circumstances.
