A2 Designs pulley review
Old Nov 14, 2006 | 06:30 AM
  #31
gregivq's Avatar
Originally Posted by mitsuozboi
My Belts squeak on start up, especially loud when they are wet or cold. (I think almost every lancer does this).
Does the shorter belts with smaller and lighter pulley stop the squeaking belt syndrom? lol
Mine are starting to get on my nerves and winter is coming and it gets worse........
It squeaks because it's either old, loose, too tight. New belts could fix your problem but yeah...a new pulley would be better
Old Nov 18, 2006 | 11:24 AM
  #32
ozrally0303's Avatar
what about the vibrations this causes on the crankshaft ive herd a couple evo and dsmers sayin that this will cause uto knock and some have spun a rod bearing i bought one but im turboed and im dont wanna risk my enigne for 5hp if that
Old Nov 18, 2006 | 11:37 AM
  #33
LancerAdam's Avatar
I have not herd of this happening I have had no problems with it at all.
Old Nov 18, 2006 | 11:41 AM
  #34
superfly78209's Avatar
will replacing the pulley and cam gear both help a lot? any possible damage to the engine?
Old Nov 18, 2006 | 11:45 AM
  #35
LancerAdam's Avatar
I have the cam gear and pulley on my car check out this thread
https://www.evolutionm.net/forums/sh...d.php?t=231001
I do not see any reason this would cause any problems. Its lighter thats about it so the engine will just spin up quicker. It helped me quit a bit.
Old Nov 18, 2006 | 11:52 AM
  #36
bahamut's Avatar
If people are concerned about dimming of headlights, just go to circuit city or some place like it and buy 1 or 2 size bigger power and ground wires + 4 terminal connections on each wire ends + optional change battery terminals.
If people know how to put bigger speakers into their car, this is surely a simple task.
Old Nov 18, 2006 | 01:19 PM
  #37
gregivq's Avatar
I finally got the belts from autozone for about $20 JohnSlowES former Lancer owner will install my pulley tomorrow morning.
A detailed review will follow.
Old Nov 18, 2006 | 01:55 PM
  #38
crypto's Avatar
Former Vendor
sweet!!!
Old Nov 18, 2006 | 08:57 PM
  #39
KillahB's Avatar
Keep in mind you own neither an Evo or a DSM. Completely different motor. For all its worth, I had a Revolutions Motorsports UDP on my Mirage aspirated for about 3 years and then turbocharged for about 1 1/2 years with no ill effects.
Old Nov 19, 2006 | 09:40 AM
  #40
i wasnt sayin it was a problem with our cars just about 5 of my firends were *****in about me buyin one and was just checkin with evom o well ill put it on and prove them wrong and hand them there asses a lil harder this time
Old Nov 19, 2006 | 12:28 PM
  #41
gregivq's Avatar
The pulley is finally installed. It took about 20 minutes. The belts fit perfectly, I guess except the long one. It could be a little bit longer but a little elbow grease and it fit.
Old Nov 19, 2006 | 12:56 PM
  #42
gregivq's Avatar
And also, a video
http://www.youtube.com/v/FYc6PLCCDpQ
Old Nov 19, 2006 | 01:28 PM
  #43
Grey_Fox's Avatar
Keep getting this error:
"This is a private video. If you have been sent this video, please make sure you accept the sender's friend request."
Old Nov 19, 2006 | 01:30 PM
  #44
Evo666's Avatar
video didn't work for me
Old Nov 19, 2006 | 01:38 PM
  #45
gregivq's Avatar
Should be fixed now.
