Engine Help
Old Dec 25, 2006 | 05:24 PM
BoosterPac's Avatar
Engine Help
hey i need some help with my motor, i have been reading up on this but i still nee some help, so i just recieved my motor from the machine shop, they rebuilt the bottom end and the head, they did no reassemble the motor though. i need to know how to get the timing belt in the right position, i know that there is a small divit on the head that lines up to the dot on the timing gear, and there is asimilar setup on the bottom end. what i need to know is how to get the bottom end and the top end in sink so when i go to start it everything is good, so if anyone has a manual or knows it would be a great help. THANKS
Old Dec 25, 2006 | 05:28 PM
smokedmustang's Avatar
Sounds like a disaster waiting to happen!! Like doing brainsurgery over the internet. GET IT DONE RIGHT!!Where do you live? Is the motor in complete pieces??
Old Dec 25, 2006 | 05:30 PM
tripperfx3's Avatar
Defiently get it done professionaly especially if you havent done it yourself before.
Old Dec 25, 2006 | 05:36 PM
ambystom01's Avatar
If you don't know how to do it, don't do it.
Old Dec 25, 2006 | 05:41 PM
BoosterPac's Avatar
HA HA i love u guys, thats the answer i needed i will got get the manual, just thought someone might have it on there computer and could post a link. thanks
Old Dec 25, 2006 | 05:44 PM
ambystom01's Avatar
Again, if you don't know what you are doing, don't do it. It's not as simple as just going through a manual, I mean there is a reason why mechanics go to school.
Old Dec 25, 2006 | 05:45 PM
phil_'s Avatar
Its not that difficult.
If the head is off the block ensure that the cam gear is lined up at TDC for cyl. 1. Then make sure the block/pistons are at TDC for cycl. 1. Basically lining up the marks. Once you have the engine assembled turn it over a few times to ensure you have the timing mark lined up properly.
Old Dec 25, 2006 | 05:49 PM
BoosterPac's Avatar
ok thanks
Old Dec 25, 2006 | 06:01 PM
phil_'s Avatar
I would definatly try to get my hands on a manual though. Just so you have the proper assembly procedure on hand aswell as proper bolt trq. specs,etc.
Make sure you clean both head/block surface very well before you install the new gasket to ensure a good seal. I would also recommend you repace the headbolts as the headbolts are stretch bolts, only designed to be tightend/torqued once. Proper tightening sequence is:
7 5 1 3 10
9 4 2 6 8
just to give you an idea of the order the headbolts should be tightened in.
Old Dec 25, 2006 | 06:14 PM
BoosterPac's Avatar
thanks alot phil, yeah i do need to get a manual, i have assembled a 4g94 before but i had a manual so just need to go out and get another one, thanks
