Eclipse parts on Lancer
Old Dec 12, 2006 | 08:54 PM
Evo_Jr's Avatar
Search page is back on for me. Web site has been slow for me to load up.
Old Dec 12, 2006 | 10:12 PM
Grey_Fox's Avatar
When I was looking for a throttle body apparently the 1G TB bolt right up, but you need to do some re-wiring on the ???idle sensor???
Old Dec 13, 2006 | 04:44 PM
phil_'s Avatar
Yes the dsm TB works. I have a bored (63mm) 1G NT DSM throttlebody, and it works nicely. You do need to rewire your tps, and IAC however. 9 wires.
You can also use a FPR kit designed for DSM's. You just need to bore out the end of your stock rail to fit.
Old Dec 26, 2006 | 12:58 PM
bahamut's Avatar
Why do you need to get that big for 63mm? A G93 IM can't even get that big w/o reaming out the IM runners.
Old Dec 26, 2006 | 01:12 PM
Mirage2.0's Avatar
I have 1g 60mm tb for sale.
Old Dec 26, 2006 | 02:57 PM
phil_'s Avatar
I ported my G93 IM out to 63mm without a problem. Basically matched the port size of the TB to the ID of the plenum, and theres still a couple mm more I could have ported away if I had a larger TB.
BTW 63mm TB w/ halfshaft mod/ported 4g93 manifold @ 9psi tuned feels nice!
Old Dec 26, 2006 | 03:05 PM
bahamut's Avatar
I don't really believe you, because I have seen AQ (owns a RA now) did it on his mirage in the beginning measurement and after burring it. Anymore, you'll bur the mounting plate and the top part of the IM runner into oblivion. We used a DSM TB gasket to mark the burring point.
Old Dec 26, 2006 | 11:30 PM
krnzzang84720's Avatar
hey phil could you please give me general describtion of your kit
1. which kit?
2. Intake Mani port?
3. your Hp/Tq
4.Q/T time
5. Picture of the kit
SoFlaBBY
Aug 21, 2013 05:56 PM
FunBeny
May 18, 2012 06:37 AM
deathangel1812
Sep 6, 2009 06:55 PM
