Install-Clutch and starting problems
you have to make sure the fluid resivoir is COMPLETELY FULL TO THE TOP after every pump of the pedal as well. fill to top, depress pedal, loosen nipple (fluid will come out), tighten nipple, raise pedal up SLOWLY, add more fluid. repeat this process about eight times. the pedal should be firm.
Yeah I found out that the fluid needed to be about 1/4 - 1/2 an inch past the MAX line....i was pretty ticked off. I fixed her on the 13th. thanks though......you would have helped a lot if i didn't figure that out....I bought a new clutch master to be safe and figured out that it needed more fluid when I took the feed line off and nothing poured out.
TeamEmperor-
Jan 31, 2017 09:02 PM
red_evox_87
Mitsubishi TC-SST Discussion
Jun 13, 2016 09:00 AM
