torque on arp head stud?
Man, it has been a while... ARPs make head studs for the G94 now? Cool! Wish I knew bro... But on our Civics we use a 3-stepped process (35, 50, then 65 - starting from the inside working out).
When you put the studs into the block, they go in hand-tight, then once the head is on, that's when you torque them. Be sure to use their assembly lubricant to get a more effective/accurate torque amount.
