Noticing something odd
Old Mar 25, 2007 | 02:06 PM
smalltown's Avatar
A couple of days ago I did the whole timing belt and water pump thing. At the same time I installed an RRM pulley. Now I'm noticing less low end pull than I had before. All thats done to the engine is an Ingen SRI. Now could the lost be from me mistiming the belt or does the weight of the new pulley have something to do with this?
Old Mar 26, 2007 | 10:38 AM
SLVROZ_03's Avatar
Yeah, you're probably a tooth off...ie retarded.
Old Mar 26, 2007 | 11:04 AM
krimson_binome's Avatar
When I did my timing belt I messed with changing it one tooth advanced and one tooth retarded. I noticed that the idle got rougher when it was off a tooth (in either direction). Since you have an sri, could the difference be due to the steadily increasing temperatures? I know my car turns into a total dog when it's hot out.
Old Mar 26, 2007 | 11:11 AM
SLVROZ_03's Avatar
To put it simply, did you mark TDC on the crank/gear against something (ie head/block) to make sure it didn't "travel" on you while installing? Unless you have an adjustable gear, I'd try advancing it one tooth and see if that'll do yah!
Good luck!
Old Mar 28, 2007 | 07:41 PM
smalltown's Avatar
Thanks for the help but I think it was all in my head now. I don't know, it just started working again like it always had. I most likely just worried it up. I had a guy at work do the job for $250 instead of going to the shop and getting charged almost $500. What do you know, he knew what he was doing after all.
Old Mar 29, 2007 | 09:51 AM
SLVROZ_03's Avatar
Did you reset the ecu after the mods? The ecu was probably learning the new mods and all! Great to hear it came out okay.
Old Apr 2, 2007 | 02:03 PM
iufan4lifeul's Avatar
RRM pulley doesn't need a computer reset. And "technically" while every once in a while I reset my computer too, there is no need to.
Old Apr 3, 2007 | 10:36 AM
SLVROZ_03's Avatar
It doesn't technically need to be reset, but It'd been a quicker way of having the ecu re-learn things...
Old Apr 3, 2007 | 11:01 AM
Evo_Jr's Avatar
+1
Old Apr 3, 2007 | 12:39 PM
exactly. But again, this is a crank pulley. Therefore computer is not affected whatsoever.
Old Apr 4, 2007 | 11:30 AM
DickMorgan's Avatar
yeah i asked the guys at RRM after they installed my crank pulley if i needed an ECU reset and he said no.......it's jsut a crank pulley, it's not controlled by the ECU anywayz, so no need to reset it.
You do however need......well not need, but it helps to reset the ECU after any of the more common mods
Old Apr 9, 2007 | 01:57 PM
chunkey_munky1's Avatar
Timing belt question.....
how hard is it to change out the timing belt? i was just wondering before i start taking the car apart.
Old Apr 11, 2007 | 05:30 AM
smalltown's Avatar
I would say if you have the money to kinda throw away then you should pay some one to do it. I love working on my car myself, but I love my running right more. If you're comfortable with setting timing marks, torqueing everything down, and having fun keeping up with all bolts and where they go; then go for it and do it yourself. A really good site I always use for info. is www.alldata.com. You have to pay for it a year at a time though but it's worth it.
Old Apr 21, 2007 | 03:28 PM
way2fast4u2's Avatar
i would suggest having it done versus doing it yourself
