Engine braking
Old Jun 14, 2007 | 06:03 PM
JTB's Avatar
JTB
Originally Posted by ex-honda
Actually that "farting" sound is the Jake brake system. Anyway I rather change brake pads than a clutch anytime, because as you go from 4-3,3-2,2-1, there is clutch wear happening there.
Clutch wear is negligible if you are shifting well. If you are slipping the clutch to get the engine up to speed then just leave it in gear
I almost never use first until I come to a complete stop.
Old Jun 14, 2007 | 09:28 PM
radicaledward's Avatar
Originally Posted by Blacksheepdj
- Get on the freeway (with no cars behind you).
- Travel at about 45 mph steady.
- Downshift to 2nd gear. Do NOT touch the gas or brake pedals.
Two things will happen. First, your engine will quickly spin up to high RPMs (but shouldn't redline, that's why I picked 45 mph). Second, your car will slow down. That is engine braking. It's a good way to scrub speed.
Another example: When I'm driving my '69 Camaro, if the stoplight turns red, I downshift 4-3, then 3-2, and then 2-1 as I'm getting close to stopping. The car slows itself to a stop just from running in a lower gear. I don't have to hit the brake pedal until I'm doing 1 mph in 1st gear and actually want the car to STOP MOVING.
Those examples help?
Yup that helps - thanks! I guess the reason that I hadn't heard about it can partly be chalked up to the fact that my car is an automatic and partly because I've always heard it as downshifting (i.e. your Camaro example).
Old Jun 15, 2007 | 07:18 AM
KillahB's Avatar
Also, while this is miniscule in the scheme of life, when 'engine braking' or using the engine to come to a stop, as the car is decelerating using the engine (i.e. when you downshift as you come to a stop), the injectors are not firing. This is as opposed to putting it in neutral where the injectros still fire as the car tries to maintain idle speed. Miniscule fuel savings but fuel savings nonetheless.
Old Jun 15, 2007 | 08:26 AM
Blacksheepdj's Avatar
Yeah, gotta love the American version of English. 87 different words for the same thing. But yet when you read a book (currently), it's spelled the same as the book you read last year.
