Installed Nitrous
Old Aug 12, 2007 | 08:30 AM
gtslancer08's Avatar
i have a link right here buddy.
http://nitrousdirect.com/nitrousoxide.html
Old Aug 12, 2007 | 04:15 PM
SeRious08's Avatar
Good luck to you. But I would have went with dynotunenitrous.com
Old Aug 12, 2007 | 04:48 PM
evolusent's Avatar
thanks guys, can't wait to see your pictures gtslancer08
Old Aug 14, 2007 | 12:32 PM
Rabidhamster's Avatar
dry or wet kit?
and with the purge cloud, it does matter the temp of the nitrous and the temp of the ambient air your purging into
deffinately let us know how your car reacts.. did you step your plugs down a heat range?... I've got an itch for a 100hp direct inject wet kit with an rpm controller.. but it'll be a bit for me.
Old Aug 14, 2007 | 03:48 PM
its a dry kit. imma see how the car reacts to a 75 shot on thursday. see how it runs all day. dont wanna blow my engine just yet
Old Aug 14, 2007 | 03:56 PM
hukster00's Avatar
What are u using for adding the extra fuel since its a dry kit ? I'm a noob to nos but with dry kits don't u need some kind of way to add extra fuel ???
Old Aug 14, 2007 | 06:47 PM
nope. just cut into the exsisting fuel line. runs good . i guess you could to make run even better.
Old Aug 15, 2007 | 12:17 PM
umm if you touched the fuel system at all ... it's not a dry kit
dry kits you only inject nitrous not nitrous and fuel.. and rely on the vehicles 02 to make the fuel corrections for the nitrous being added
sounds like you've got a single fogger wet system.. which would be the lowest kit I would recommend to anyone (I stay far far far away from dry kits.. they are what give nitrous a bad reputation... that and silly people)
Old Aug 15, 2007 | 11:21 PM
Green_Bandit's Avatar
Interesting...I want to see how this turns out.
Old Aug 18, 2007 | 09:45 AM
angryGTS's Avatar
get it tuned.....
Old Aug 18, 2007 | 10:32 AM
lancerman360's Avatar
Yeah if you have a dry kit, there is no reason you should even touch a fuel line.
I would actually never ever install a dry kit on any car. It throws off your air fuel ratio and you will run super lean when you spray. This makes it super hard to tune and very dangerous for your motor.
I really dont see your car lasting more than a few years, but good luck anyways. Maybe these new lancers can hold up.
Old Aug 18, 2007 | 10:39 AM
Evoryder's Avatar
cool
Old Aug 18, 2007 | 12:06 PM
if you don't think the lancers engine will hold up to a 50hp nitrous shot... stay the hell away from a turbo
BTW.. efi engine will compensate for a dry kit.. but much more then 50-60hp is starting to really push it (this is for 4cyls ofcourse)
I can 100% garuntee that I can make the same hp gains with nitrous just as safely as any of you can out there with a reputable turbo kit. and I'm willing to bet that my engine will also last longer on the simple basis that I can turn mine completely off and still drive as aggressively as I want too.
hmmm maybe I should make a nitrous 101 thread LOL .. we can get all the nitrous myths and legend squished and the real facts brought to life...
it still boggles me that people will gladly bolt up 100+hp worth of turbo kit.. but think a 50hp nitrous kit is gonna kill an engine
Old Aug 18, 2007 | 12:18 PM
Um no it wont. If you didnt know its N"O"2 The "o" is oxygen. That means when you spray, you are putting in more air than your car thinks and therfore running lean.
And YES turbo kits are way safer than any dry kit ever invented. Maybe you should do a little research before you make a thread about this subject.
Old Aug 18, 2007 | 12:27 PM
Blacksheepdj's Avatar
N2O.
What was that about research?
