Leak down test
Old Aug 23, 2007 | 08:43 AM
Mirage2.0's Avatar
Leak down test
How many psi stock 4g94 should hold? What kind of results should you see?
Old Aug 23, 2007 | 09:36 AM
SLVROZ_03's Avatar
I know on my Civic (1.6L) the Helms manual says 200 per the factory...but would the 2.0L make that # higher or lower?
Free bump for someone that has a repair manual.
Old Aug 23, 2007 | 09:37 AM
Mirage2.0's Avatar
Someone, please!!!
Old Aug 23, 2007 | 09:45 AM
Silens's Avatar
if you are talking about a compression test, i got 185 across when i was stock
Old Aug 23, 2007 | 10:16 AM
Mirage2.0's Avatar
Leak down.
Old Aug 23, 2007 | 12:02 PM
Blacksheepdj's Avatar
Any of this it? I'm on AllData under Engine Pressure Specifications...
Compression pressure (200 r/min) Standard value 1,618 kPa
Limit Minimum 1,176 kPa
Compression pressure difference of all cylinder Limit 98 kPa
Curb idle speed Standard value 700 +/- 100 r/min
If that's the wrong data, I'm sorry. I don't know exactly how to find Leak Down numbers unless it flat out says "A leak down test should show results of..."
Old Aug 23, 2007 | 12:13 PM
Mirage2.0's Avatar
^These are compression numbers or what?
Old Aug 23, 2007 | 12:19 PM
Again, I have no clue. I went to "engine specifications" and this was all I saw. I just posted it hoping that it would be what you need.
Old Aug 23, 2007 | 12:33 PM
otter's Avatar
EvoM Administrator
There's not really a set pressure level to do a leakdown test. Also, at least a tiny bit of air will always get past the rings, so a cylinder will never hold air for any length of time. The purpose of a leakdown test is really to deduce why a cylinder isn't holding pressure. So, first off you want to do a normal compression test. Then, if you find a cylinder is running low compression, you do a leakdown test to figure out where it's leaking.
Old Aug 23, 2007 | 12:40 PM
apexernsx's Avatar
For a 20-30,000 mile engine from an Evo, Porsche, Mercedes, you should be in the 3-7% range. 10 and above is suspicious and especially if 3 cylinders are at say 4% and the fourth is at 10.
Old Aug 23, 2007 | 12:42 PM
otter's Avatar
EvoM Administrator
Yeah, I was just about to add in that a 5% loss is typical, thanks
Old Aug 23, 2007 | 12:56 PM
Mirage2.0's Avatar
I will get my leak down results today. And since I have 11.0:1 pistons, I just wanted to compare the numbers.
asu11
Jun 26, 2016 05:50 PM
westcoastkid
Lancer Aftermarket Forced Induction Tech
Jul 21, 2015 09:18 AM
deathangel1812
May 17, 2009 06:19 PM
Rice7x
Jun 26, 2007 03:55 PM
