At the Track Lancer De with pulley Against Lancer GTS Stock Both Manual
Old Sep 10, 2007 | 09:55 AM
Mystic_Korean's Avatar
Does the DE come with rear disk brakes? I wonder what the difference would be in a track, not a strip. How much difference the suspension / brakes would make.
Old Sep 10, 2007 | 10:26 AM
kiioichy_EvoIII's Avatar
Sorry mate, us DE owners don't have rear disk brakes but imo the benefits of having rear disk brakes would be distance travelled before a complete stop would be reduced for certain feets less than having drums in the rear. Believe me it sucks having drums. Suspension: stiffer ride= more control on curves, and brakes the same thing as the rear disk brakes, quicker stops.
I'm planning on making a rear disk brake swap from an evo as some guys here in Puerto Rico did to their Ghymkana GTS, that swapped all the braking system with the one that the evo IX has.
Anyone, correct me if I was wrong on anything.
Old Sep 10, 2007 | 01:47 PM
Mark Hubley's Avatar
As I have discussed on another thread (some would probably say "ad nauseum") stopping distance on a single stop is limited by tires, not brakes. So, if your goal in life is to be able to stop the car in less distance for a single stop, forget about upgrading the brakes and get bigger wheels/tires.
The big advantage of the discs over drums is that disc brakes dissipate heat much more effectively than drums. So, the GTS will have a big advantage over the DE under conditions of repeated, demanding stops that occur on a track.
The advantages of the GTS over the ES in terms of braking are more subtle. Over a single stop, the advantage of the GTS will be modest and related only to the difference in contact patch from the slightly wider tires. However, the bigger discs of the GTS will dissipate heat more effectively than the smaller discs of the ES, resulting in more fade resistance that might show up on a track.
Old Sep 10, 2007 | 01:54 PM
P.S. During the first few laps on a track, the weight advantage of the DE might allow it to keep up with a GTS, which has the suspension/handling advantage. However, it shouldn't be long before the DE brakes become a serious liability. Over 20 or so laps at a place like Summit Point or Watkins Glen, the GTS should do much better than the DE.
Old Sep 13, 2007 | 07:40 AM
WADADLIG_OZ's Avatar
Well said...
Nice to have some new knowledge entering the Lancer ranks.
WADAD
Old Sep 13, 2007 | 07:43 AM
To the original poster...
Without the slips we cannot truly tell what factors may have played into your WINS.
If the GTS drivers stood there and burned their tires off the line being too agressive it would show up in the 60 foot times and we could really see some differences.
If this trend does hold true of all the DE's then it would prove my point that 1/4 mile wise the DE or ES would be a better car to buy to modify for that purpose.
Trackwise though I like the information contributed above. I never thought about that.
WADAD
Old Sep 13, 2007 | 11:27 AM
WADAD,
Thanks for the comment. Now we just need to form the '08 Lancer road-racing circuit!!!
Mark
Old Sep 13, 2007 | 03:26 PM
08LanceRage's Avatar
um yeah...
Old Sep 16, 2007 | 12:11 PM
evo-monstar's Avatar
what significant drag does the gts body kit have on the car and its drag?
does the Gts come with a LSD?
hey for the rear disc breaks lets look for a crash 08 lancer at a juckyard and buy it and do the switch !!!
i think is more likely to be more agresive in mods with a ES or DE than with a GTS! my 2 cents
Old Sep 16, 2007 | 12:16 PM
ambystom01's Avatar
I doubt drag is a problem considering the speeds we're talking about.
Old Sep 16, 2007 | 06:05 PM
Blacksheepdj's Avatar
Drag - probably not a ton. But I don't know if anyone other than has numbers.
No LSD on the GTS.
Old Sep 16, 2007 | 10:49 PM
Jay8141's Avatar
Yea sounds weird
Old Sep 17, 2007 | 03:38 AM
oh ok thanks but yet where the time slip !!!!
Old Sep 17, 2007 | 11:13 AM
Hydrolikz's Avatar
^x2
Old Sep 17, 2007 | 12:32 PM
LancerGTS's Avatar
Have you all forgot? This is a thread about how awesome RRM parts are. Proof isnt needed. You wont be seeing any slips.
