Sequential Shift Light Question?
Old Jul 23, 2003 | 01:31 PM
agent5568's Avatar
I bought a sequential shift light like you see on the rally cars. I know one of you guru's out there know the answer to my question. I need to know which pin on the CPU controls the RPM output to my factory tack. Or which wire coming out of the instrument cluster is RPM sending wire. It says either on will work. I already tried every wire on the backside of the instrument cluster so I would prefer the info on the CPU. I have a 02 Lancer OZ m/t. Help!
Old Jul 23, 2003 | 01:40 PM
Sailorgoon's Avatar
There is a US Lancer wiring diagram available on this site. Let me see if I can find it.
Old Jul 23, 2003 | 01:41 PM
Sailorgoon's Avatar
Here you go, try this:
https://www.evolutionm.net/models/la...irediag.php?s=
Old Jul 23, 2003 | 02:00 PM
agent5568's Avatar
Man- I appreciate it and I have been all throught that wiring diagram that is posted on this site. I cant make heads or tail out of it. If you know what specific wire or pin I need to splice into I would appreciate it. Surely someone on here has hooked up an aftermarket tack. Thanks!
Old Jul 23, 2003 | 02:37 PM
VA_LANCER_RACER's Avatar
28p, I have the ecu diagram if you want
Old Jul 23, 2003 | 02:51 PM
agent5568's Avatar
VA Lancer Racer- Man thats great! Please send the diagram to agent5568@msn.com
Old Jul 23, 2003 | 07:11 PM
agent5568's Avatar
That was it! Thanks!
Old Jul 23, 2003 | 08:29 PM
no prob glad to help, btw the diagram I sent you was from the sfac install tutorial just fyi, oh what kind of tach did you get? pivot?
Old Jul 24, 2003 | 05:00 AM
agent5568's Avatar
I got a rev-lite from T-Sport like what is on the F1 cars.
Old Jul 29, 2003 | 08:54 AM
agent5568's Avatar
Actually - That was the RPM signal wire and it only showed the the low end of the RPM band, The correct wire turned out to be pin 58 and that wire is Green/white. The shift light works awesome, you set it to redline and it starts to light up in 200 rpm increments until you reach the green light at redline. I love it. I dont even watch my tach any more!
Old Jun 11, 2004 | 10:46 PM
mrauqinas's Avatar
Bro, can you send me the diagram msujanto@rogers.com
Thanks man!
Old Aug 1, 2004 | 08:25 AM
nrgaura's Avatar
Please send the diagram to nrgaura@charter.net
Old Aug 4, 2004 | 07:40 PM
Alchemist's Avatar
Here's the diagram If you look closely you'll see that the RPM wire is green with a little white or silvery stripe on it.... and that IS the one because these are the pinouts I used for my eManage
Old Aug 4, 2004 | 07:42 PM
Alchemist's Avatar
how much did you pay and where did you get the shift light?
